60, 65, or 70?
60, 65, or 70?
1984.5 GT 5.0 5 Speed ANALOG
BBK Long Tubes/H pipe/FM
Edelbrock Intake/Holley 600
8.8 w/FMS 3.73s
Steeda Shifter
2010 GT 5 Speed DIGITAL
Track Pack
Pypes Violator axle back
Airaid Cold Air
AFAIK, max on a stock Mustang was 60. Tbirds had a 65 but you have to reclock it in order to make it fit.
Ok, 60 is all I could find for a 1g without plug
8.8 w/FMS 3.73s
Steeda Shifter
Track Pack
Airaid Cold Air
In the 90's and early 2000's I bought two 65A 88 Tbird alternators for next to nothing because they didn't fit anything else. then I'd clock them and put new brushes and bearings in. When I was young and first starting out with my family and barely had the cash to keep my car on the road even at junk prices I was mighty thankful for my ability to recognize how I could make one off cheap parts fit and also for my car that seemed like it was going to run forever.
If it had 1/2 the life back that I beat out of it racing for cash in college it probably would have never needed any engine work in my lifetime.
A testiment to turning up a stock car then leaving well enough alone.
You can rebuild them for higher amp output. There are limits to about 100 amps. I'm not sure if they really put out that much and there is not a wiring upgrade to go with it. I never had one fail. All of this is if you want stick with the stock look.
That's a ton of power from a stock appearing alt.
Anyone have details on how to do it, what mods are required? What's the max for the stock wiring?
Stock wiring is a single 10 guage with is only good for a maximum of 40 amps continuous. Lots of guys have fires if they do an upgraded alt and dont touch the wiring.
Go 3g if an upgrade is worth it. The stock alt is okay with no big stereos or electronics. You want anything more, then do it right.
My 3g put out over 75 amps at idle. Under load it actually hit over 160 amps and it was a parts store taurus replacement. My stock setup only pushed 20 amps.
I've ran huge amplifiers for years but my stereo spends most of its time turned way down.
Ive always ran a 800-1000 CCA battery to help carry the load for a song or two.
i see upgrades in my future. What year Taurus alternator?
1993-1999 Taurus, some F150 4.9 trucks, some Panther frame Lincolns. Both i6's 3.3 from 79 to 82 in Capris and Mustangs, and everything V8 from 1978 to 1993, if you have a serp belt.
Because I'm an I6 er, there is some 130 to 200 AMP I6 upgrade info thrown in there too
(Mike 1157 http://vb.foureyedpride.com/showthre...elt-conversion
JackFish https://fordsix.com/viewtopic.php?t=62869 )
http://vb.foureyedpride.com/showthre...g-3G-read-here
Originally Posted by fordconvert
"http://vb.foureyedpride.com/showthread.php?29434-3G-Interchange-Facts-If-you-re-thinking-3G-read-here"
The biggest problem with the 2G alternator is the power connectors (spade type) and harness. They're fire starters. The 1G has an external regulator. They both also have an external cooling fan and exposed fan blades (<100A). @ the plastic "finger" guard.
The 3G has a lug connector for power, and internal fan and regulator.
I think the electrical inards (rectifier, stator, etc.) are also improved in the 3G.
Read all of the following links
For 2.3's
For I6's 78 to 83
JackFish
For Mike1157 in line six serpentine conversion
For all other Serpentine belt 5.0's
Clarko's link has the following dead links.
http://rothfam.com/svo/3g/
http://www.oldengine.org/unfaq/3ag/3ag.htm
http://www.bcbroncos.com/3ginstall.pdf
Its a fun and super easy swap. Dont let the clocking scare ya, and dont waste time with a high end expensive installation harness.
To re clock, unbolt the three long screws, turn alt until the screws line up again and you are done, test fit it first to make sure it went the right way.
I had to cut off a small triangle shapped rib on the stock alt bracket, if you remove the bracket it would take 30 seconds with a hack saw. I was lazy and decided to do it in the car with a 4" angle grinder. Its close to the gas lines, i was focusing on them so much a rubbed a spark plug wire. The new alt isnt threaded on the top hole. Buy about a 1/2" nut and bolt, about 1 1/2" long. I think i just went with a 2" long bolt and never got around to cutting it down.
For the wiring, you can either use a factor harness from a junkyard (they gave it to me for free at the junk yard, any 3g setup will work. Crown vic, taurus, mustang, 94-97 3.8 v-6 tbird ect). Most fuse holders at the yards also have a 175 amp fuse either on the side of the fuse holder or near the battery tray.
Otherwise, they sell repair harnesses for about $20 or less at any parts store. Everything goes on, color for color on the stock wiring at least for me. If you strip back the double "chargine wires" a couple inches, they splice down to a single black w/yellow stripped wire. This runs to a fuseable link, you can either hook it to the new yellow wire for voltage sensing or tape up the old wire and tuck it back in the old wires and loop the yellow wire to the discharge stud.
I bought a cheap "mega fuse holder" at napa and mounted it with some sheet metal screws. For $12, i might just use an old starter solinoid just to be cheap next time. I also bought some 6 guage "starter cables" for $8 right of the wall next to the battery stuff at any parts store. You can get these pre crimped in any length from 6" to 72" and not even have to splice the charge cable. I put the fuse holder next to the battery.
Worked fine for about 3 days, then my $13 junkyard alt died on me, ended up dropping $100ish on the taurus replacement at a parts store.
Basically, if you are frugal and okay with using junkyard stuff, you can do this swap for anywhere from $50 to buying everything new and spend about $250.
When I did my 3G swap I used the conversion harness for an 86 mustang ($15 and comes with the connectors and resistor already connected). Get about 8' of #4 welding cable, lugs to go with that, megafuse holder (175a) and then various connectors for 18-10g wire plus a few inches of 12g wire (had it laying around, actually too big). The conversion harness comes with instructions and is super easy, just take the bracket off and grind a small chunk out of it. This way you can remove the external regulator but plug into the factory harness in case you ever want to switch back.
