Hello, all:
I want to pull the intake manifold off the 86 GT for cleaning. That will require new gaskets. Not a major problem but I am open to any advice. Some folks use the small end gasket pieces, others apply RTV to the ends of the lower intake. As the factory used the two end pieces, should I continue or use the RTV? No leaks but I do want a good seal. I've also heard to apply RTV to the water ports to help seal those areas. I think the most work will be removing old gasket material and making sure the surfaces are clean. I plan to use Fel-Pro gaskets. Last time I replaced the thermostat I installed it 'dry', no RTV or water pump gasket stuff. Just a little to hold it in place. No leaks in three years thus far. Lastly, what tricks can anyone off for actually cleaning the intakes?
Thanks much.
