So, I've seen countless threads about this. Guys want to convert an early Fox to 8.8 with dual exhaust, and want to use the 8.8 style brake lines on the axle housing. Well, the problem always was that from the factory, Mustangs with dual exhaust and 8.8 used this stupid, impossible to find banjo adapter fitting where the brake hose attached to the center of the body. ONLY Ford used this, ONLY on the '86-95 Mustang, NO ONE made it in the aftermarket, and it was even impossible to cobble something together that would do the same job the same way. So, if you wanted one, your only option was to find someone parting a car out.
Until now. LMR is making and selling them! This is a HUGE deal for anyone wanting to make this conversion!
https://lmr.com/item/LRS-2073BRKT/mu...-bracket-86-93
Anyway, I just found out about this, and thought I'd share. Now, if we could just get them to make the LTD wagon gas tank sending unit...
