Results 1 to 25 of 31
    FEP Power Member BLK BRD 88's Avatar
    Dec 2010
    Next to the Chimney
    Default 84 1C Slapper Bar SVO Stored in the northwest
    Here are a couple tag pics for foxchassis of the 84 that we recently purchased in Spokane Washington and have stored there for now:
Size:  108.3 KBName:  Door tag.jpg
    Mick, can you please decode the buck tag for me?
    I never seem to get the nut that holds the steering wheel fixed
    Dec 2010
    Next to the Chimney
    Here are a couple of pics of the car as it was received:
    Name:  SVO Left wallyworld:cropped.jpg
    Name:  Left rear low W: windmill cropped.jpg
Size:  99.9 KBName:  SVO Low right side W:Windmill.jpg
    VIN
    1FA = Ford vehicle manufactured in USA by Ford Motor Company
    B = active belts, no airbags
    P = passenger car
    28 = Mustang 3-dr hatchback
    T = EFI turbocharged intercooled 2.3L engine
    1 = VIN check digit
    E = 1984 model year
    F = Dearborn Assembly
    144763 = 44,763rd 1984 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 12/83 = December 1983 scheduled build
    GVWR - 4010 lb/1818 kg = gross vehicle weight rating
    Front GAWR - 2124 lb/963 kg = front gross axle weight rating
    Rear GAWR - 2013 lb/913 kg = rear gross axle weight rating
    F1666 = 1666 lbs front accessory reserve load
    R1333 = 1333 lbs rear accessory reserve load
    Exterior Paint Colors - 1C = Black
    DSO - 74 = Phoenix district sales office
    Body - 61B = Mustang 3-dr hatchback
    Int Trim - MA = leather SVO Articulated Sport seating (M), Charcoal interior trim color (A)
    A/C - [blank]
    R - 8 = AM/FM stereo with auto-reverse cassette tape player
    S - C = sunroof
    Ax - R = 3.45:1 axle ration, Traction-Lok differential
    Tr - 2 = manual Borg Warner transmission (5-speed T-5)
    JJ = front springs
    MM = rear springs
    Buck Tag
    MUSTANG = Mustang model line
    MO = moonroof (sunroof)
    015_ = body & paint rotations #015_
    1CC = Black exterior paint color
    DF
    ST
    AC = manual air conditioner
    12 = YES rear defrost, YES dual rear wing
    HB = heated backlite (rear defrost)
    SVO = SVO model/trim level
    RM = rocker molding
    WD = power side windows (W), power door locks (D)
    MBW = manual Borg Warner transmission (5-speed T-5)
    05 = hole in hood w/ functional hood scoop
    ELECTRIC
    -A = Charcoal interior trim color
    EI = electronic injection (EFI)
    NLR?
    04?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Dec 2010
    Next to the Chimney
    Thanks Mick,
    I knew that somewhere on the buck tag it stated whether it was a single or dual wing, but didn't remember where. The original order form has
    "Single rear spoiler
    Power door locks/Trunk release"
    written on the face of it in black ink. The balance of the writing to fill out the form is brown, so it is probably a carbon copy.
    I wondered about this, but the (12) on the buck tag shows me that it did come with dual wings originally.
    Ron
    If the build was a mistake, and it was supposed to have come with a single wing rear spoiler, it would not be the only one.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Dec 2010
    Next to the Chimney
    Are you saying that it would not have been the only 84 single wing around, or that it would not be the only one ordered with single wing that didn't come out the door like it was ordered?
    Ron
    Other SVOs that were specifically ordered with a single-wing, but were mistakenly built with a double-wing, have been documented.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    I did not know that "single wing" option was available in '84. My understanding is that became available in '86 and yes, there are documented instances of mistakes being made on the assembly line with that option.
    86 SVO 2R Comp Prep
    86 SVO 9L Comp Prep
    86 SVO 7B Comp Prep
    The 1984 Car Facts Book, in the Mustang SVO and standard equipment sections, indicates that the single wing rear spoiler was optional on the SVO, but it is not in the optional equipment list in that same book. It is also not mentioned anywhere in the the 08/83 or 12/83 U.S. showroom brochures, or the 5-9-83 Rapid-Spec Ordering Guide.
    It is mentioned extensively in the 1985 literature.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Dec 2010
    Next to the Chimney
    Hello All,
    OK, nearly five months later, and we are back visiting grandkids in Spokane.
    We have retrieved the SVO from where we left it stored while away, & are getting it ready to drive to Az. in a few days.
    A far as I can see, it is ready to make the 1500 mile trip, but then with a thirty year old car who ever knows!
    Ron
    Quote Originally Posted by BLK BRD 88 View Post
    Hello All,
    Ron
    Good Luck! Hope everything goes well for you on the return trip.
    Dec 2010
    Next to the Chimney
    Thanks Trey,
    We start for home Monday Morning and are only going as far as Twin Falls Idaho the first day, then to St George Utah the next day, then home Wednesday.
    Ron
    Jul 2016
    Duncannon PA
    Good luck and safe travels.
    Take at least the basic tools with you plus the tool for the ignition mudule. A small tool box goes with me on every long trip with an old car. You never know.
    Dec 2010
    Next to the Chimney
    Quote Originally Posted by dagenham View Post
    Thanks Dagenham, but I have to plead stupidity on that one. I have a small tool box with some of the essentials including duct tape, bailing wire etc.
    I am not sure what an ignition module tool looks like.
    Are you talking about the ignition switch module on the steering column?
    Ron
    Dec 2010
    Next to the Chimney
    Well, I never did find out what tool for the ignition module I needed before leaving Washington...........?
    On the way home, we took a side trip through St George Utah. One of the places that we stopped along the way was Marble Canyon/Glenn's Ferry which is just before the Colorado River drops into the Grand Canyon.
    This is a pic of the SVO parked near the river.
    Name:  Ron standing by the SVO at the river.jpg
    Anyway to finish the story, we made it home without mishap or vehicle problems and the SVO is now safely parked in the garage in Humboldt Az.
    Ron
    Sep 2010
    Lexington, MA
    1C, Leather, slapper bar, and Moonroof? The ultimate '84 SVO!
    Dec 2010
    Next to the Chimney
    Bryan, I am not sure how many others on this site would agree with you about that, but we sure do!
    Jan 2006
    Western MA
    Congrats on the road trip. The module mentioned above is the Ignition Control Module (ICM) or sometimes called the TFI. It's mounted to the side of the distributor and requires a special small socket to remove the 2 x hex headed fasteners.
    Mine died earlier this year less than 10 miles from my house. Ended costing me ~$100 for a tow.
    1986 SVO Mustang - 1C
    FEP Senior Member ddx77's Avatar
    Jul 2011
    Fort Lauderdale, FL
    Congrats on the safe trip! That photo is awesome! Car looks great!
    Ron
    Dec 2010
    Next to the Chimney
    Thank you for that info jturbo.........I kind of suspected it was for the TFI, but wasn't sure that was what dagenham meant.
    Thanks Drew,
    Sue & I really enjoyed driving it on the trip, even that many miles with no cruise control wasn't that bad.
    Ron
    That's a pretty good shake down trip. How did it do?
    Sent from my SM-G892A using Tapatalk
    Dec 2010
    Next to the Chimney
    Quote Originally Posted by brian.aughe View Post
    We feel that it did quite well during the 1500 mile trip.
    On the last day of the trip, it did flutter/stutter once, so I shut it down and then restarted it and it was back to purring as it should.
    (I will be replacing the fuel filter and hoping I don't have to drop & drain the tank).
    It only averaged about 23mgp...............I was hoping for a bit better mileage, but I couldn't resist spooling it a up a bit around many of the great curves between Spokane & Arizona.
    Overall, it was a nice trip for the two of us in a 33 year old sporty little Ford
    Ron
    Dec 2010
    Next to the Chimney
    Here are a few pics of how it looks now, since we have gotten it home with some clay bar work, a few coats of wax, and a new redline stripe:
    Attachment 118846Name:  Front left driveway:cropped.jpg
Size:  116.5 KBName:  Engine compartment:front.jpg
    Mar 2013
    DENVER CO, the 303
    Looks great, amazing work
    Apr 2009
    Denver, Colorado
    Sounds like it was a good trip.
    Link for TFI tool..I have 2
    https://lmr.com/item/LRS-TX646/Tfi-Module-Tool
    Current rides:
    89 LX 5.0, 5 -spd..the Lemon
    86 RS Capri 5.0 Auto...
    85.5 SVO, Finally Got Boost
