Results 1 to 4 of 4
    FEP Member Dogster's Avatar
    Nov 2005
    Huntington Beach, CA
    Default Hot Air Tube to Air Cleaner Clamps
    Bought some OEM Ford Hot Air Tube (Headers to Air Cleaner) for my 85 GT. Can't remember what the factory clamps looked like but I want to try to find some. Anybody have any pics of the original clamps? Ditto for the radiator, bypass and heater hoses. Thanks!
    '85 Mustang GT Convertible, Jalapeno Red, Charcoal Int., Black Top, 5.0 H.O., 4 bbl , 5 speed, No AC, All original except for 8.8 Motorsport rr w/3.55 gears & subframe connectors. Owned since 'August 86. 1 of 574.
    I believe these to be my original air tube clamps.
    Sorry, can't help with the coolant hose clamps. Hopefully someone else can shed some light on those.
    Thomas
    Apr 2012
    Springfield MO
    Default Radiator hose clamp views
    You can see the top radiator clamp in this photo if you look closely. I can get more later if needed.
    and this from a 82 back when it was new
    MCA #110307
    83 GT T Top
    83 GT Convt
    84 GT Convt SOLD 08/18
    Nov 2005
    Thanks guys! That's what I thought they were but memory was a little hazy. Now I know what to look for!
