I just purchased an 85 GT with 44k original miles. Previous owner installed B springs with stock struts and shocks.
It rides rough and I do not like it at all. I see some people say they run Bilsteins with B springs and say they match very well.
Problem is I can't figure out what model they are using exactly.....or is it that they switched to 87+ spindles?
I need a high quality strut/shock I can use, what does everyone recommend?
Has anyone used the Eibach struts and shock kit with "B" springs?
If not then I will follow Trey's advisement and go with the Eibach pro kit. Thanks again Trey for your help.
Also does anyone know where I can get a smaller diameter sway bar for front? Think that may also help ride a little.
