I bought replacement oil caps for my valve covers on my 84 carb 5.0. They fit good the problem is they're a little taller and the PCV valve is hitting the air cleaner inlet on the drivers side. Does anyone know of a shorter PCV valve that fits our oil cap grommets? Single inlet is fine. The top tube is capped off on the PCV valve anyway because my emissions equipment is gone.
thanks
