Results 1 to 15 of 15
    Question How do I repair plastic threads? Hydraulic line female threads top cylinder convertib
    How do I repair plastic threads? Hydraulic line female threads top cylinder convertible, Loctite super glue gel?
    Super glue type gel would fill some gaps. But would it seal and hold under extreme hydraulic pressure?
    Does Loctite make a gap filling thread sealer, especially one for plastic to metal, maybe an epoxy?
    Should I superglue gel, then epoxy around the top threads?
    May 2014
    Royal oak Mi
    Have pic ?
    Mar 2014
    Omaha, NE
    It depends on the extent of the thread damage to what actions could take place to repair it. If we cold get a few pics of said area, it would make repair ideas easier.
    Brock
    OK, I am thinking superglue gel and epoxy, Name:  IMG_9363.JPG
Size:  168.8 KBName:  IMG_9364.JPG
Size:  183.2 KBsecured with bailing wire.
    Mar 2014
    Omaha, NE
    Ewww, I see now. That's going to be a bit of a complicated fix without just replacing the cylinder if all the threads are pulled out or missing like the top ones appear to be.
    Honestly, about the only "fix" that "might" hold there, due to the pressure, fluid and type of plastic would be using a Helicoil and hoping for the best. No guarantees there that it will work or the mating areas for the lines won't be damaged. Once the Helicoil was installed, the cross wire would have to be snipped to allow the hose end to mate with the cylinder.
    Not knowing for sure what type of plastic that part is made out of will make thinking about a "fluid" type repair sketchy at best. Super glues are very particular about what kind of plastics they are on, and even epoxies/putties have their limitations on what they will bond to also. Being a pressure part, and one that is not the easiest to access when mounted in the car, I would really ponder going the route of a new or used cylinder that has good threads. I don't know that a fluid fix would be worth the hassle, time and expense of trying it and possibly have the hose pop back out.
    I'm sure that this isn't really what you wanted to hear, but I don't know of any sure fire fix for it. Maybe someone has done it successfully before and will chime in.
    Brock
    DuPont pipe dope.or thread sealer
    Mar 2014
    Omaha, NE
    ^^^^ That will also work as long as there are threads left to screw into. If you do and it is only the top few threads that are messed up, clean them up with a tap of the proper size/pitch and apply pipe dope. I like to use Rectorseal Tru-Blue as it is a thick vibration resistant dope/sealer.
    Brock
    May 2014
    Royal oak Mi
    Not sure how much wall is there before it breaks out but you could make a sleeve with knurled outside wall and then glue it in and you could also mill some of that face down say 1/4 inch and tap the plate for that hydraulic thread and add (2) screws on the corners and you can only add a plate as thick as you mill it down so your hose ends and feed hole connect
    Not sure if it's worth all that trouble though compared to new unit if it were me I would make a insert tube possibly and you could even (pin) the tube in the plastic so it would act as a "anti rotate" and not free spinn in there but you can only pin it say half the wall or so of insert you can't drill through it of course
    Appears to be nylon for material
    Try to find the female fitting at a hydraulic store and take it to machine shop as a thought if glue doesn't work for you
    I like the helicoil idea backed up with JB Weld. To help take the pressure off the threads, cut some notches into the brass and plastic corners and then wrap some wire around the hose fitting and the plastic. Picture hanger wire is good. A couple of wraps around the mating parts then take the ends of the wire and twist them together. It will pull everything up tight. The notches will keep the wire from working loose.
    W
    Jul 2010
    Houston (Clear Lake), Texas
    Given the plastic lines and nylon top, I doubt there is much pressure on the system. That being said, Home Depot carries a 2 part putty that will cure under water...I keep some in my boats just in case... I have used it to plug holes and it works great. I would utilize that over a liquid epoxy in order to keep it out the the system and possibly plugging up something else.
    HAD
    HAVE
    I kept putting globs of superglue gel on the male fitting threads and trying to screw it into the nylon female side. I tried a few times with it getting cockeyed, and finally gave up on the hand job… kidding couldn’t resist that pun. Glue was deposited and filled in threads on both sides. I couldn’t get 7/16 14 or 20 taps and dies to bite right, so I cleaned out the male threads and used that fitting as the tap. I installed a vice, and used a c-clamp to hold the pieces in final assembly position, and tapped the threads while installing the fitting. The c-clamp kept the sealing flange from the male fitting tight against the mating seal surface while I used an open end wrench to tap threads. I backed the fitting off, put liquid superglue around the shaft, tightened a turn, put jb weld epoxy around the threads, and tightened er down, then pressed epoxy into fitting thread interface. I used bailing or picture wire to tighten and secure everything in a fixed position, and covered sharp edges with duct tape.
Size:  165.6 KBName:  IMG_9366.JPG
    May 2013
    Berea Ohio
    Super glue will most definitely NOT fix your problem, it just flat out doesn't work on engineering plastics (the "slippery" plastics) such as nylon and delrin, and when you mix in any kind of chemical contamination then it really sucks. Your best bet *might* be JB Weld but even that's a crapshoot. The one thing you absolutely have to do when using any adhesive is make sure all of the bonding area is spotlessly clean to ensure a good bond.
    8. No selling outside of the Classified areas. If you've something to offer to someone for free, or the cost of shipping, it's 'legal' to offer in the other areas. If you're dying to let someone know you have something they may want to purchase, then send them a Private Message OR an email via the board. Do NOT post an offer in a non-classified thread. Posts will be edited or removed by staff without warning.
    Please keep all offers to sell and buying to PM's. Otherwise post an ad in the Classified sections.
    Thanks!
    Thanks for all the good tips guys.
    O Ring is the solution. It was leaking around the shaft, the guy who said he would sell me 2 top cylinders for $25 flaked out. So, I looked for a replacement. I saw that the guys selling new ones were including o rings. I did not recall any o rings when I replaced the broken hoses. So, I clipped my retaining wires, and tightened the fitting… still leaking. I unscrewed the fitting, installed o ring, screwed fitting down until it bottomed out and kept turning. There was enough thread to keep it secure even though I think it was still somewhat stripped. It didn’t leak. So, I re-did the epoxy to secure the fitting in place, and declared victory.Name:  IMG_9437.JPG
Size:  152.2 KBName:  IMG_9438.JPG
    Not so much flaked out as should have checked that what i had was good enough to sell. I could have boxed em up and took your money, but I'm not that guy. I will make sure from now on before I offer a part to anyone. Once again sorry, my bad
