Well i ordered 2, 1157-r27-t led bulbs and forgot to get the other two .i installed the two on the passenger side. The brake light works , but the turning signal does not. My question is do all four bulbs need to be the same.
The turn signal thing might be because you need a no-load flasher. Amazon has them.
The standard flasher should be just your average 2 prong 552/536 12v thermal flasher.
All you need is the a low/no load flasher with the same 2 prong setup. You can often find them at the average McParts store. Otherwise Napa/Carquest can help you out for what you need. Just FYI all of the flashers that I have seen are electronic and not thermal for the low load/no load flashers. Good Luck!
Trey
http://www.ebay.com/itm/122130476504...%3AMEBIDX%3AIT
I put these in my 84. They come with reverse polarity adaptors in case you need them.
I have led taillight assemblies in my 66. The kit comes with a flasher that has a ground wire. IIRC isn't there two flashers? One for the turn signals and a second one for the hazard lights?
