Hello I'm new here and trying to solve a leaking coolant problem in my 83 gt. It has the original but built 5.0 in it. The coolant appears to be leaking from the oil pan gasket but it is hard to tell. I changed the oil less then 500 miles ago and the coolant was leaking then but there was no coolant in the oil? All I can see is that it drips off the oil pan gasket and down to the front sway bar. Maybe its from somewhere else that I can't see. Seems to only leak when the car is warmed up to normal running temperature. Any sort of help would be greatly appreciated!
