Results 1 to 2 of 2
    Default 85 GT Steering Wheel slip ring contact?
    Good evening,
    I apologize if there is an existing thread for this, but I cannot seem to get the search function to work.
    I was working on my 85 GT this last weekend trying to get the horn to work. I found that if I grounded one of the leads on the horn switch, the horn would make noise. I could hear the solenoid above the glove box clicking also.
    I tested the switch and it was also good. after a bit of head scratching and wishing I had gone to the store to get beer I noticed that the contacts for the steering wheel slip ring were missing.
    which explains why I had so much trouble fixing it.
    does anyone have a part number or source for a replacement?
    Thank you
    For an '85 GT with the cruise control steering wheel, the contact plate is E5ZZ-13A808-A or E6ZZ-13A808-A.
    The contact brush assembly is E6ZZ-9C899-A or E9SZ-9C899-B.
    Cheers,
    Jeff Cook
