How are you guys running the wires for the coil when you do the SEFI swaps? I pulled the engine harness from my 86 GT and the coil runs in the body harness bundle along the drivers side frame rail. Do you cut out the wires for the ignition and swap them too or is there enough wire to go from the stock (passenger) to EFI location (driver)?
