Page 5 of 5 FirstFirst ... 345
Results 101 to 115 of 115
  1. #101
    Sep 2016
    Anchorage Alaska
    Car looks amazing compared to when I saw it in the spring! Meanwhile the parts I got from you are still in the same storage container I put them in after I got home...
  2. #102
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Thanks Matt.... I can't wait to see the Fairmont build get started
  3. #103
    May 2017
    Beaverton, Oregon
    Ok, the EFI swap is finally finished, and is running well. Got the body all back together, interior in the car for the first time in 10 years, and I also got the carbon fiber inner aprons installed. Here is a pic of the inner aprons... hoping to clean up some of the wiring, but it works well for now:
    Here are some pics of the car back on the ground and assembled... after a maiden trip around the block
    Crazy to think that it started like this only 9 months ago:
  4. #104
    Apr 2010
    Portland, Oregon
    Nice looking MAF
  5. #105
    Sep 2016
    Anchorage Alaska
    Looking good!
  6. #106
    A lot of nice work man love those carbon fender aprons!! And those seats too. I've seen those seats fade pretty quick so beware. Not sure how well scotch guard will help but worth a shot lol. Because they are a great looking seat.
  7. #107
    Looks great! Congrats!
  8. #108
    Looks great!
    -Randy
    '83 Mustang GL notchback - 351w - T5Z
    '84 Mustang GT350 20th Anniversary Hatch #2808 - 302 - T5
    ''92 Mustang LX Hatch - 2.3t - IRS (in progress)
  9. #109
    Looks awesome! Nice work
    85 GT - owned since 87
  10. #110
    May 2017
    Beaverton, Oregon
    Well, I bit the bullet after realizing that I cheaped out on only one area of my suspension.... the coilovers. The Raceland coils are a good option for general driving, but since I've decided that I want to try a little bit of track time, and some additional dampening adjustability, I contacted the good guys at Maximum Motorsports, and got their front and rear coilover kits, a set of Koni shocks and struts, and a set of MM Caster/Camber plates. They recommended 300# front springs, and 175# rears. I am looking forward to getting them installed this weekend, and seeing how it feels on the road. Here is a pic of the coilover kits, still waiting on the Koni struts... should be here Friday.
    The last thing I am considering is Maximum Motorsports Track Bar. I have the Panhard bar, and just trying to determine if the addition of the Track Bar would make a significant difference, and/or if there are any negative affects that the Track Bar would have on my car as a weekend driver?
  11. #111
    Quote Originally Posted by vdubn View Post
    I assume you mean Torque Arm rather than Track Bar.
    I would say go for it! The difference in handling is night and day IMHO. Well worth the $$ and definitely a great addition to any Fox street or track.
    The only downside is your current coilover springs will most likely be too soft and would require a increase in spring rate. If you are serious, you might consider giving MM a call and see if you could return your new uninstalled set for the correct spring rate before you go any further. Best of Luck!
  12. #112
    May 2017
    Beaverton, Oregon
    Oops... Yes, Torque arm. I'll call MM today and see what they say. My next question... Which Torque arm to buy? Also, it sounds like some exhaust modifications are required, depending on which mid-pipe your running. I'm running a MAC ProChamber mid pipe. I wonder if it will need to be modified?
  13. #113
    FEP Senior Member wannabe82's Avatar
    Jan 2009
    Savona,NY
    You have put in some serious work on your beautiful car.
  14. #114
    May 2017
    Beaverton, Oregon
    Thanks for the compliment. Much appreciated. Couldn't have done it without this community.
    Trey, I talked with MM today and they recommended moving up to 200# rear springs... So I'll exchange my 175a for those. I also found a HD Torque Arm, brand new, for a killer deal. Hopefully I'll have it by this weekend.
    Anyone here done a Torque Arm install to know how difficult it is compared to the Panhard bar install?
  15. #115
    [ATTACH]118610[/ATTACH
    Hey, hoping this still reaches you although you’ve sold the car a while back... currently in the process of building an 85gt hatch, same color lol. Just had a question on your rear fenders, did you have to pie cut as well, or only have to roll them?
