Results 1 to 19 of 19
    FEP Senior Member shovelhead 93's Avatar
    Aug 2007
    Peterborough,Ontario Canada
    Default Horsepower opinions
    Stock 87 H.O. bottom end, fly cut pistons, comp xe274hr, AFR 185 heads 58cc, 41 thou compressed head gasket thickness, comp roller rockers,long tubes weiand stealth with Holley 650 double pump. How much power do you think it makes.
    Shovelhead 93
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    320-350-ish at the crank. A single plane intake might work a bit better up top. More carb wouldn't hurt, either. It depends on how high you are willing to rev it up, too.
    410hp @ 6500rpm.
    1983 Mercury Cougar 3.8L LS
    1981 Mercury Marquis Brougham
    1971 Mustang Fastback
    1974 Pontiac Luxury LeMans
    Feb 2012
    Blog Entries
    2
    Think so? My imaginary dyno needs a calibration ---
    May 2005
    Altoona, PA
    Well since we're just guessing I'll throw mine out there. I'll say 325 at the wheels, so around 370ish at the flywheel. Probably need to wind it up pretty good for those numbers.
    408/T5/3.73's
    Aug 2007
    I had hoped for close to 400 at crank, but probably way off.
    Shovelhead 93
    Aug 2005
    Plymouth, Ma.
    I built a similar combo years ago. 306, flat top pistons, xe274 hyd roller, Edelbrock rpm heads, Performer rpm intake and 750 Edelbrock carb. made 320 rwhp and 310 rwtq. Your combo might do better with those AFR heads.
    85 G.T. All motor
    337 c.i.d 11.44-120 mph
    88 L.X. Hatch 5.0L H.O.
    5-speed. 13.41-102 mph on E.T. Streets winter beater
    1984 1/2 G.T. 350
    13.09-106 mph
    1979 Pace Pace car 2.3L Turbo (Daughter's Car)
    Anybody remember Joe Sherman's (Joe Sherman Racing Engines) 400 horsepower 302 (306) build-up with the backward-installed flat-top pistons? The magazine/s (June 1998 "5.0 Mustang" magazine was one...) mistook the compression ratio at 9.54:1, when it was actually 10.54:1. It used early ('64 to '67) 289 small chamber 54cc heads, ported, with Chevy 1.94" (reduced to 1.88" for plug clearance) 1.60" valves, ported intakes, an Isky 280H flat tappet hydraulic camshaft, and stock rocker arms... and the results were:
    - Performer RPM: ~370ft-lbs @ 4500rpm & ~388hp @ 6250rpm
    - Victor Jr: ~370ft-lbs @ 5000rpm & ~401hp @ 6500rpm
    To quote Mr. Sherman: "... To put the 400 HP in better perspective, I did a vintage road race 302 last year, and with AFR heads and a solid roller cam, RPM intake and 750 carb. It made 477 HP at 7500 RPM. A good 306 will make 430-440 HP if everything is real good."
    ... crickets... guess my age is showing, lol...
    I found the old-school, low-buck, ported iron 289-headed (10.54, not 9.54:1 CR), carbureted, 400-horse 302 article:
    Heck yeah, I love old articles! I'm guessing she'll make 370-375ish. A single plane would do more on the peak.
    1984.5 G.T.350 had since 16y/o
    95 Cobra, Crystal White
    Jan 2007
    Quartz Hill, California
    I am betting 350-360 to the wheels, I have that same cam in my RS and it runs strong up to around 6,250 RPM on my build, maybe higher on yours because of the heads.
    Robert
    My RS in Action
    Jan 2003
    lansing, mi
    I'm going to say 310hp at the wheels.
    Cale
    There are SO many factors that go into what these motors will run. Actual lift and duration of the valve is not just a function of the cam -- it is hugely influenced by how well the valves are controlled. Then you start seeing what happens across the rev range and up top where parts love to make their presence known by breaking.
    How many of us have heard of guys getting exotic with valves, retainers, springs, lifter tweaks, and even oil pressure and pushrods..... and getting past 9000 out of a stock cam HO engine? Oh - not many but some.
    I used to make fun of my dads habit of cranking oil pressure up to the moon until I started really looking at it. Eventually you start to see how oil pressure influences lifters and short of nearly bottoming them out on purpose or shimming them near solid it's one of the few other ways to realize the lift potential of a cam. About the time he was coaxing mostly stock part in Chevy 283's and 327's and Buick 350's from the 60's and 70's era past 8700 -- willingly -- I saw his point. But the devil is in the details and things like being able to retain bearings at high oil pressure and volume comes into play for sure.
    Sufficient to say my 351W with fuelie heads and 360 degree offy on top got some of the same treatments and surprised the living hell out of most people - even me.
    Heres an article that is a great read for anyone trying to coax horsepower out of their build that's searching for answers on why their combo is coming up short given the sum of the parts:
    http://www.mustangandfords.com/how-t...oller-engines/
    When you start to look at some of the tricks employed in coaxing RPM out of basically junk parts it becomes clear why the tricks can't really be used on a street motor.
    Anyway - fun stuff.
    With a great set of heads on a 302 with a stock cam and 1.7:1 rockers and decent headers and induction and spark should be able to kick out just slightly north or south or 400 at the crank at 6000. If it's not, i would start by looking at valvetrain.
    cheers!
    Aug 2007
    Well I had it on the dyno 2 passes. The first one didn't get a reading second one was 285/288 at tires. All cars that made 2 passes were down around 20 horse from first pull, really hot day. I hoped for more but that was with plugs that were fouled, haven't had a timing light on it yet and running rich (fouled plugs). I have since went from 67 main jets to 65 mains. Seems to have helped as it isn't popping at high rpm anymore. daryl1980mustang.pdf
    Shovelhead 93
    Jan 2004
    Arlington Washington
    See your hp curve was still climbing at 6500, so had you been able to spin it out farther the 185 heads probably would have made a bit more power for ya.
    1982 Capri RS 5.0L
    1985 SVO 2A & leather.
    Jan 2007
    Should have a lot more in that combo.
    Robert
    My RS in Action
    My bet is timing is needed. Maybe more base, maybe heavier weights, maybe vacuum advance problems showing their ugly self. Just a guess.
    There's a LOT left with a proper tuning session. I think 325 at the tires is easily achievable with those parts.
    Aug 2007
    Yes I agree, I had considered one of the aftermarket fuel injection setups, but I think based on the price in Canada I will try some tuning and see what I can get,.
    Shovelhead 93
