Results 1 to 7 of 7
    Default Neutral safety switch plug
    Some one cut the harness on my sons 79 and the plug from the car is missing. Where can we order a replacement 4 hole female end that comes from car to trans harness?
    Jul 2012
    Georgia
    Probably the easiest thing to do would be to reach out to a local transmission shop, they'd probably be able to source one for you if you can't find one easily from NAPA or someplace like that.
Size:  95.8 KB like this one? How much wire do you need to go with it?
    I believe that's the one i need
    Yep thats the one you need son.
    Measure twice cut once hopefully, lol but you never know.
    Default pigtail
    Rock Auto has some pics of these.
    Listed under electrical-connector, ICM connector.
    Shows close ups of pin socket and shape/type/location of connector retaining blades.
    May or not be the same as the transmission one.
    Local auto stores prob have them if one knows what to ask for if a trans pigtail is not listed.
