Results 1 to 2 of 2
    FEP Power Member ScreeminChikin's Avatar
    Sep 2002
    Kansas City, KS
    Default Manual steering with A\C
    Anybody running a manual rack but keeping their A\C? I would like to see what your accessory drive\belt routing looks like. I assume that since the compressor is located roughly where the power steering pump would be with the FMS A\C delete bracket that it would be similar but I don't recall ever seeing one with this setup.
    '90 LX Sport 5.0\T5
    '90 GT 331\T5
    '90 Notchback 5.3LS\S480 Turbo\TH400
    Quote Originally Posted by ScreeminChikin View Post
    running without smog pump or power steering. But using the math from the diagram if you still have smog pump, you should be able to use a 77" belt and route it like the left middle picture, except also going around the smog pump to the alt.
