Results 1 to 6 of 6
    Default Correct Holley rebuild kit part number confirmation
    Im trying to research the correct rebuild kit for the original holley on my 83GT
    Carb is: E3ZE-9510-AUA
    List - 50093
    2232
    What I am coming up with is holley part # 3-1346 or 37-119 big price difference between the two so I am assume
    one is just gaskets? Also possible that neither are correct
    here a link to the chart of kits, http://documents.holley.com/techlibr...al_listing.pdf
    Just want to order the correct one. Should I Call Holley on Monday, or can anyone confirm what kit is correct?
    600 cfm simular to the 4160?
    Thanks!
    FEP Senior Member qikgts's Avatar
    Jan 2010
    Rockledge, FL
    3-1346 is the right one for factory Holley 4 barrels on '83-'85 5.0's.
    '85 GT
    The other one... 2005 Lincoln LS 3.9L V8
    +1 for the 3-1346. The 4180C may -look- similar to a 4160, but few of the internal gaskets interchange
    with a 4150/4160.
    Cheers,
    Jeff Cook
    65 coupe, 289 auto, Pony interior ... '67 coupe 6-cyl 4-speed ... '68 Vert, Mexican block 307 4-speed...
    '71 Datsun 510 ... And a 1-of-328 Deep Blue Pearl 2003 Marauder 4.6 DOHC, J-Mod, 4.10s and Lidio tune
    Thanks guys, I will get one ordered.
    Did you guys run the single stage 4.5 power valve that came in the kit? There are no markings on the stocker other than it looks like a two stage.
    Jan 2010
    Rockledge, FL
    The last rebuild I did on mine was about 6 years ago and I used whatever was in the kit. It may have been a 2 stage but I didn't take any notes or document anything to say for sure.
    The link below lists several 2 stage valves for sale if you are looking for a source.
    http://www.carburetor-parts.com/Carb...lve_p_62.html#
    '85 GT
