How to seal rust inside fuel tank??? Gas-proof paint? Just Wire Brush Sender?
The sender or fuel gauge that resides in the fuel tank is covered with rust. I am afraid that rust will shed and invade other components like the fuel pump and carburetor. Is there a coating I can spray on that is gas resistant? There is also black slime on lower components of the sender.
I plan to clean it up with gasoline then carburetor cleaner and plastic brush, then wire brush. Maybe I will put a fuel filter in the rubber fuel hose inline before the metal fuel line going forward.
The sender is expensive enough, and working well enough not to replace. This restoration is getting very expensive already.
