Results 1 to 6 of 6
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Default Issue viewing post
    I've had this happen once before but with another thread and I just blew it off back then. I guess it was with in the last 45 days or so. This time I figured I'd let someone know.
    When I try to view the post:
    Stanley Re-chargeit 15 amp reconditioned an old battery… Good Restoration Tool no aff
    Started by 83v6Stock, Today 12:10 PM
    The site loads the following page:
    Any suggestions?
    '85 GT
    Apr 2010
    Portland, Oregon
    Did the same to me. Try clicking on the thread title, worked for me.
    See here: http://vb.foureyedpride.com/showthre...using-Problems
    I removed the three periods in the thread title and now I can open it. I may have to remove the hyphen also.
    Non alpha-numeric characters in thread titles is no bueno.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    It worked fine for me within the last few minutes. Thanks for the edit.
    '85 GT
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    I think I found the other post that didn't work right.
    "Thomas’ 1985 GT Build" in "Online Car Show/Show & Tell". I was able to change the url in my browser and view it but if the title could be fixed on that one it would be appreciated as I responded and subscribed but the notification email sends a bad link that won't parse.
    '85 GT
    My build thread is the one qikgts is referring. I've had problems opening it also, but only when trying to pull it up on my android mobile devices using chrome browser. I haven't had issues doing so on my home or work PC's. Home PC is Win10 w/ edge browser, work PC is Win7 w/ IE 11.
    Thomas
