Hey all,
I just picked up an 84 SVO which seems to have the mods to turn it into an 86 power-wise. It also has an adjustable frp and boost controller. I'm having one annoying issue with the car. When driving, it will slowly raise the idle every time I come to a stop. Say I set it to 1000 with the screw, if I drive down the road and stop at a light, it will be at 1100. Drive a little more and stop again and it's at 1400, it just does this until I lower the idle screw at which point the cycle will repeat. I have reset the base idle, cleaned the IAC with carb cleaner and checked the TPS voltage as well as set it properly and it still does this. Any thoughts on what to do next?
Thanks!
