Results 1 to 6 of 6
    Default Measurement for swaybar mount
    I need a huge favor! I need a measurement to the front of the swaybar mounts from the radiator support. (86GT)
    Any help would be fantastic, new rails are complete, but need to double check on the mounts before final weld.
    Marc
    1968 mustang, 1986 mustang gt... One done, one still slow.
Size:  55.3 KBName:  14934798940022114832918.jpg
Size:  57.7 KB Sorry they are a tad dark. I would call it 11 7/8 to the front edge of the bracket to the spot where the rail spot welds to the rad support
    Thank you! Exactly what i needed! Rep given.
    The dangle angle on pic 1 is off a tad.that's why I measured again without the camera. I'm comfortable with the 11 7/8. I'm not sure those cars were built within 1/8 tollerances
    So, i just couldn't see spending 100bux to buy the replacements, for what they are, so we spent a little time at the fab table today..
    Hopefully get them welded in tmrw nite!Name:  20170430_184055.jpg
    Some guys are putting a triangle between the bolt holes for strength. depending on your useage you may or may not need them. I think mm sells the piece so you can see what I mean. Just a thought. Looks good!
