Page 7 of 21 FirstFirst ... 5678917 ... LastLast
Results 151 to 175 of 516
Thread: Pace car build
  1. #151
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Quote Originally Posted by cougman67 View Post
    It’s a long weekend and I’m told we must work on the yard. I am spending some spare time stripping parts and believe it’s a pace car hood after all. I hope to know better tomorrow. I just need to keep the boss happy.
    Well the boss has a smile of her face so you must be doing things in the correct priority I did my garden yesterday and spring cleanup last weekend so I have a day to the car today
    Can you comment on the stripping product you are using? I looks to be working well. I have not used any myself before and I am curious on the procedure and results.
  2. #152
    Nov 2011
    Alberta, Canada
    Thanks Trey. I’ve owned 5 pace cars and none had the kidney opening. Everything I’ve measured indicates it will fit. After removing the white I see what appears to be pewter so it seems that it might be the real deal.
  3. #153
    Nov 2011
    Alberta, Canada
    After cleaning the underside of the hood, it appears as the picture here is pewter. Some of the other areas looked grey or pewter and this is the best indication it’s pewter.
  4. #154
    Jan 2006
    Western MA
    Great work on the hood.
    Here is the difference between 79 and 82+ hood:
    1986 SVO Mustang - 1C
  5. #155
    Nov 2011
    Alberta, Canada
    I am using pro form aircraft paint stripper.
    It works well with th exception of factory paint and rocker guard.
    For those of you who haven’t seen any power block episodes, check this out.
    https://powernationtv.com/episode/DM.../cobra-cleanup
  6. #156
    Nov 2011
    Alberta, Canada
    Thanks for the information about the hood differences. It makes sense that the 79-81 hoods were the same. I find it interesting that some may have th kidney bean opening. I never had one with an opening before.
  7. #157
    Nov 2011
    Alberta, Canada
    The hood came out pretty good. Very little previous damage. As for the fender, that’s a different story.
  8. #158
    Jan 2006
    Western MA
    I’m sure you’ll make quick work of that fender.
  9. #159
    Nov 2011
    Alberta, Canada
    I told my wife and wanted to strip today. She didn’t see the same humour I did. I epoxy primed the hood and decided to use the new jobber fender. Name:  841E0D94-B18B-4715-88BA-FE5BD0575723.jpg
  10. #160
    Nov 2011
    Alberta, Canada
    The inside of the hood
  11. #161
    Looks like progress! I’ve been following the build, thanks for sharing!
  12. #162
    Nov 2011
    Alberta, Canada
    If anyone is interested, page 3 is an article from the local newspaper.
    http://www.lloydminstersource.com/as...unnin_2018.pdf
  13. #163
    Nov 2011
    Alberta, Canada
    Found the build sheet and pace car registration from a folder my wife found.
  14. #164
    Nov 2011
    Alberta, Canada
  15. #165
    Jan 2006
    Western MA
    Cool stuff. I filled out one of those registration sheets back in the 90's and mailed it.....
  16. #166
    Nov 2011
    Alberta, Canada
    Installed the hood and passenger fender on. The hood took some effort and work to fit reasonably well. After a few hours, I think it will work.
    Name:  Pace Car Hood.jpg
  17. #167
    Nov 2011
    Alberta, Canada
    And only one picture upside down.
  18. #168
    Jul 2016
    Duncannon PA
    Is it easier to adjust the body panel with the car over your head??? Lol
  19. #169
    Nov 2011
    Alberta, Canada
    Well if you consider the only original panel left is the cowl, you might be right.
  20. #170
    FEP Power Member Saturn V's Avatar
    Jan 2011
    Houston, TX
    Nice article. And what a cool local newspaper with such a focus on motor sports. Haven’t seen anything like that around me.
    Present: '84.5 Mustang GT T-top, '06 Mazdaspeed6
    Past: '79 5.0 Capri, '86 Buick GN, '90 Mustang GT, '92 SHO, '95 SHO
    Browse cover pages of my Fox Chassis related library
  21. #171
    Wow
    What a nice build.
    Keep up the good work - maybe one day I will start mine again but until then I will enjoy this build
    1984 Mustang LX
    302, Holley 4bbl 600 vac sec
    B&M C4 R servo
    Shorty Headers
    MSD Box and Coil
    Scorpion Roller Rockers 1.6
    Crower Cam 472 112 seperation
    Chetah Shifter
    Performer RPM Intake
    Carter Electronic Fuel Pump
    Accel Eletronic Dizzy
  22. #172
    Nov 2011
    Alberta, Canada
    Hello all, I spent the day working on my hatch for the pace car. It doesn’t seem to be too bad for an original hatch.
  23. #173
    Nov 2011
    Alberta, Canada
    To strip the areas that had rust, I tried a blaster that attaches to a high pressure washer. It seems to work well in small areas.
  24. #174
    Nov 2011
    Alberta, Canada
    Now onto the repair.
Size:  91.2 KBName:  51D1BF8D-17B5-4E60-8982-B6E52DD5428D.jpg
Size:  54.7 KBName:  03B275EE-3000-4E62-B663-C4CDA1336AFE.jpg
  25. #175
    Nov 2011
    Alberta, Canada
    The holes on the outside were welded as well.
    And just a picture of the car sitting outside while I clean the garage.
