Page 6 of 21 FirstFirst ... 4567816 ... LastLast
Results 126 to 150 of 516
Thread: Pace car build
  1. #126
    I know you have a ton of stuff going on. Just going back to the quad shock discussion that I don't believe ever got "finished". You HAVE to do something. I'm not saying I know the best "Something", just that you do have to address it. I am not saying I have the answer but I have experience. I removed them on a @200HP car once and made no other changes. It was almost undriveable. Seriously. You could not take off even sort of aggressive from a light, let alone race. The only change made was removal of those. Same wheels, same tires etc. Trey is usually on point with his response so I would suggest follow his suggestions.
  2. #127
    Nov 2011
    Alberta, Canada
    I have to remove the quad shocks and will be buying a few more parts from maximum Motorsports. It might be a while before I place another order though.
  3. #128
    Nov 2011
    Alberta, Canada
    I cleaned up the damage on the hood. It was siliconed to keep the debris out.
    The good news is that the hoodscoop will cover most of this damage.
  4. #129
    FEP Member BrentX1's Avatar
    Dec 2008
    St. Charles Illinois
    Awesome job! It is going to be great when you finish. Keep up the good work!
  5. #130
    Looking great so far. Keep it up!
  6. #131
    So far so good! Keep it up!
    -- James
    My four eyed foxes:
    past foxes -
  7. #132
    Nov 2011
    Alberta, Canada
    Another weekend update. I repaired the hood, at least the area that is visible when the scoop is on. The hood is in rough condition but I will keep it, enough parts have been replaced......
  8. #133
    Nov 2011
    Alberta, Canada
    Sunday was a good day, I primed the hood, one fender and cowl. Once that was done, I lowered the car for the first time since I installed the subframe connectors.
Size:  88.3 KBName:  013D9F26-29A8-4B69-B24B-579018C1CBC5.jpg
  9. #134
    Jul 2016
    Duncannon PA
    Not to get off the subject cougman but what brand wheel dollies do you have under your car and do you like them? I have a set of the cheap ones from harbor freight and they are horrible. It's still all I can do sometimes to move a car around with them.
  10. #135
    Jan 2006
    Western MA
    Getting closer to paint!
    1986 SVO Mustang - 1C
  11. #136
    Nov 2011
    Alberta, Canada
    I had a a set that were not very good. These ones were purchased at a local place in town and work very well. You don’t need to,jack up the car and the wheels are much better quality. They are expensive but worth it.
  12. #137
    Nov 2011
    Alberta, Canada
    Not much new to report. I started to clean the wheelhouse on the car.
    I should be spending more time in the garage since spring took a vacation this year....
    What have you done to clean the surface rust in the back? Sandblasting, rust remover liquid?
  13. #138
    Quote Originally Posted by cougman67 View Post
    I generally just use a product like Eastwood's Rust Encapsulator. https://www.eastwood.com/eastwood-bl...over-rust.html
    If you don't want to use something like that, then a rust remover such as Evapo-Rust is the way to go. https://www.evapo-rust.com/ you can often find this at the large box stores and your local auto parts supply house.
    The Evapo Rust will be difficult to use in the wheel housing, but you can brush on and try to keep wet with a soaked rag or towel held in place by tape or magnets. Not the easiest option, but it does work. Good Luck!
  14. #139
    Nov 2011
    Alberta, Canada
    That’s great, thanks.
    My bottom section, frame rails ets will need cleaning before I use any of these products. I wish someone locally had a water blast system.
    Patrick
  15. #140
    Nov 2011
    Alberta, Canada
    I haven’t done much the last few months. Today I purchased a hood and scoop this is supposed to be from a pace car. The scoop is a 79 part number so it seems to be correct. What I don’t know is if the hood is original or not. Memory tells me they were different at the latch. Does anyone know where the part number is?
  16. #141
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Nice find on the hood. I'm not 100% sure but I thought all the hoods that had the cowl or forward facing scoops had the kidney shaped hole in them?
    I picked this one up a few years ago. It was off of an 80 Cobra to my knowledge. The hood part number was visible on the underside.
Size:  113.7 KBName:  IMG_6386.jpg
Size:  110.4 KBName:  IMG_6389.jpg
    Darran
  17. #142
    Nov 2011
    Alberta, Canada
    Thanks, I couldn’t find a stamp there. I can only find a stamp on the reinforcement as shown.
  18. #143
    Jul 2016
    Duncannon PA
    Those are date codes. The D9ZZ part number painted on like that probably makes that hood a Ford parts replacement hood not one that was put on at the assembly line.
  19. #144
    Nov 2011
    Alberta, Canada
    Thanks, I thought they might be date codes, however I don’t know what they decipher too. I would expect 9A13 but this does not look the same.
  20. #145
    Jul 2016
    Duncannon PA
    Date codes on sheet metal is different than date codes on other parts. I cant make out what the numbers/letters say though.
  21. #146
    This is what I have found on Ford Sheet Metal Date codes.
    Name:  Sheet Metal Date Codes.JPG
  22. #147
    Nov 2011
    Alberta, Canada
    Thanks trey, I guess from what I’m seeing, I don’t have a year of manufacturing on these parts. What was the difference between a 79 and 80/81 hood.
  23. #148
    Nov 2011
    Alberta, Canada
    It’s a long weekend and I’m told we must work on the yard. I am spending some spare time stripping parts and believe it’s a pace car hood after all. I hope to know better tomorrow. I just need to keep the boss happy.
  24. #149
    Nov 2011
    Alberta, Canada
    A little off topic, has anyone been watching Detroit muscle?
  25. #150
    I don't know that there is really any difference specifically from the 79-80/81 hoods. I am sure there might be some difference as Ford made changes/improvement during production. Obviously only the 79 PC received the full Hood Scoop for the 79 model. The Cobra received the same scoop for the 80/81 models.
    I personally have never seen the full PC/Cobra hood scoop on a hood without the kidney bean cut out on the underside, but I can't confirm that the standard hoods didn't receive the scoop too. Obviously the scoop can be retrofitted to any 79-82 hood with just some measuring and drilling of the mounting holes, so . . . . . . . .
