Page 2 of 21 FirstFirst 123412 ... LastLast
Results 26 to 50 of 516
Thread: Pace car build
  1. #26
    Nov 2011
    Alberta, Canada
    Thank for your input. As for the quarter, do you mean the cut outs for the trim (see picture)? If so, it doesn't appear to be a big modification. I considered a repair but the quarters were repaired long ago and it's starting to rust again. From what you stated, have you replaced quarters on a fox body?
    IName:  IMG_0192.jpg
  2. #27
    Nov 2011
    Alberta, Canada
    I haven't done much on the car this summer, too busy enjoying the new toy. Name:  IMG_0114.jpg
  3. #28
    Well, if that isn't a nice toy too! Now just take the drivetrain out of it and out it in your PC!
    I'm sure Trey has replaced a quarter or two in his time. If you need any help, let us know. I don't have as much fox specific panel replacement (though some) as Trey, but I have lots of experience with countless other models.
  4. #29
    Nov 2011
    Alberta, Canada
    My latest update. After debating what to do, I finally decided to do a full replacement. There are a few differences that I was not aware of. The groove in the quarter panel where the hatch struts are located are a different design. Other than that, they appear to fit reasonably well.
    Removal in progress
    Notice the section I removed
    A section from the original quarter
    Test fit
  5. #30
    Nov 2011
    Alberta, Canada
    I have been unsuccessful in finding quarter panel patches for wheel house repairs. Has anyone used fenders or have any tricks up their sleeve they can let me in on?
  6. #31
    Jan 2006
    Western MA
    I patched the inner wheel wells on my 82 GT (where they meet the q-panel) using patches cut from old fox mustang fenders. Not a direct fit, but it worked well considering I have not way to form panels in my garage....
    Unfortunately the pics are hosted on photobucket so you won't be able to see them....
    Your work on this Pace Car is coming along nicely.
    1986 SVO Mustang - 1C
  7. #32
    Nov 2011
    Alberta, Canada
    Thanks for the information. I was considering doing exactly that and hoped someone else had succeeded in performing this repair. Hard to believe there are still not many parts available.
  8. #33
    Nov 2011
    Alberta, Canada
    You’re seems as though the fenders work for wheel houses. I am using a combination of glue and spot welding.
    This is the glue I used
  9. #34
    Nov 2011
    Alberta, Canada
    Almost ready for the panel installation.
  10. #35
    Nov 2011
    Alberta, Canada
    Has anyone used Cleco clamps to align panels or just used self tapping screws. I’ve used self tapping screws with reasonable success and just wanted to know how well it works.
  11. #36
    Nov 2011
    Alberta, Canada
    Worked on it again today. I purchased a pneumatic hole punch and will start working on it this weekend.
    The hole punch beatS drilling holes
  12. #37
    This is quite the ambitious build. Good luck in keeping motivated.
    Sent from my SM-G892A using Tapatalk
  13. #38
    Nov 2011
    Alberta, Canada
    The great thing about a long weekend is I can spend some time in the shop. I finally began welding the quarter in only to have issues with my Hobart welder. The spool ran out and I purchased a new .025” role only to find it doesn’t role evenly.
    Here are some progress pictures.
    Before I installed the quarter, I changed the location of the drain hole to the wheel well instead of the rocker panel.
  14. #39
    Nov 2011
    Alberta, Canada
    Some final test fitting with Cleco fasteners followed by spot welds
  15. #40
    Nov 2011
    Alberta, Canada
    Welding process.
  16. #41
    Nov 2011
    Alberta, Canada
    Cleaning up the welds.
  17. #42
    Jan 2006
    Western MA
    Good progress on that quarter panel.
  18. #43
    Looking great! Keep up the good work!
  19. #44
    Nov 2011
    Alberta, Canada
    I’ve finally completed the installation of one quarter. As mentioned previously, the main differences were extra holes in the quarters, the window openings are different and the area where the hatch struts mount needed substantial modification.
    Below are the results.
  20. #45
    The quarter looks good! Nice work!
  21. #46
    Nov 2011
    Alberta, Canada
    Now on to the driver side quarter panel.
  22. #47
    Nov 2011
    Alberta, Canada
    The drivers side is now removed. It must from experience.
  23. #48
    Nov 2011
    Alberta, Canada
    I am still working on the drivers side quarter panel. Here are a few pictures of the part numbers.
  24. #49
    Nov 2011
    Alberta, Canada
    A few pictures of the difference in the quarter panel opening.
    New quarter panel
    1979 quarter
  25. #50
    Nov 2011
    Alberta, Canada
    The inside profile from the side.
    New quarter panel
    1979 quarter panel
