Page 11 of 21 FirstFirst ... 910111213 ... LastLast
Results 251 to 275 of 516
Thread: Pace car build
  1. #251
    Nov 2011
    Alberta, Canada
    I found someone to drill out the holes for the tie rod ends. I’m still not happy with maximum Motorsport. They have excellent introductions but it’s all in separate manuals. On to the good news, the machinist did and excellent job and everything fit well.
Size:  91.5 KBName:  72FE41A3-59ED-4A2E-AE71-E180EBD0289A.jpg
  2. #252
    It appears that you are going to want to loosen those spindle bolts up and put some load out on the end of hub to get some initial camber in a range wherever you can adjust it into spec.
    great progress on your build!
  3. #253
    Nov 2011
    Alberta, Canada
    I’ve asked maximum Motorsports to provide me some basic settings for the car. It might be a while before I can provide them with my height etc. I’ll let everyone know how good the basic settings are.
  4. #254
    Nov 2011
    Alberta, Canada
    Out family went to Cabo for Christmas. While it was good, I didn’t have much opportunity to work on the car. I did manage to fix my quarter panel to door adjustment. When I installed the new quarter panel, I used the door as the reference point. I was lucky enough to purchase rust free doors but the driver side door didn’t fit well. I finally took the plunge and performed some reconstructive surgery.
    Before:
  5. #255
    Nov 2011
    Alberta, Canada
    The repair process:
Size:  76.6 KBName:  69864A32-FCC9-4DB2-B505-C0B3362D5ABE.jpg
Size:  54.7 KBName:  69864A32-FCC9-4DB2-B505-C0B3362D5ABE.jpg
  6. #256
    Nov 2011
    Alberta, Canada
    Realigned:
Size:  64.0 KBName:  2F939386-3211-4CF3-BA94-5DAE19BD22B5.jpg
Size:  48.9 KBName:  0925DB79-6DCB-4CF8-B27D-26A60B3B5544.jpg
  7. #257
    Nov 2011
    Alberta, Canada
    Another great winter day up north. We received 6” of snow today so I worked in the garage between shoveling. I prepped and painted the drivers door and door jamb.
  8. #258
    Jan 2006
    Western MA
    Fresh paint, no matter how much or little always looks great!!!
    1986 SVO Mustang - 1C
  9. #259
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    No kidding!
    I'm curious on the masking on the jamb to the body and how you mask it later when you do the exterior. I did not perform well on the last one I did. When I painted jambs first and then exterior on our Tangerine car and had/have some overspray/transition spots I rather not.
  10. #260
    No kidding!
    I'm curious on the masking on the jamb to the body and how you mask it later when you do the exterior. I did not perform well on the last one I did. When I jambs and then exterior on our Tangerine car and had/have some overspray/transition spots I rather not.
    Name:  3M Edge Masking.jpg
    Or mask and spray to a hard line or edge on the body. That will prevent the average person from being able to tell where you had to do a respray.
  11. #261
    Nov 2011
    Alberta, Canada
    Thanks guys, I hope to use a combination of foam taper regular tape with a rolled edge. I hope it works.
    This weekend was to continue painting doors and fenders. If only I had a larger garage.
Size:  92.4 KBName:  83BC53BC-5D52-454C-9854-8D67E441277A.jpg
  12. #262
    Nov 2011
    Alberta, Canada
    I have to leave the quad outside until I can install some of these panels.
Size:  87.0 KBName:  008CCAF2-53F5-4F56-AAED-76D6EF1AD236.jpg
Size:  75.8 KBName:  751A60E4-CEA2-4621-A812-98DA2D084FAB.jpg
  13. #263
    Nov 2011
    Alberta, Canada
    The paint even matches and it seems close to the original colour (colour for my Americans).
  14. #264
    Quote Originally Posted by cougman67 View Post
    I think you mean COLOR for us Americans!
    The Pace Car looks Good! Congrats!
  15. #265
    Nov 2011
    Alberta, Canada
    Damn spell check. LOL.
  16. #266
    Looks great . Really wish i had the skill to put a finish down properly.
  17. #267
    Oct 2014
    Calgary, Alberta, Canada
    No, he got it right, you folks need to learn to spell properly. But I'll do you a favour and won't belabour the point. After all we need to be neighbourly.
  18. #268
    Nov 2011
    Alberta, Canada
    Question for everyone. What paint is everyone using for the black on the bottom of these cars? I was contemplating SEM black as I’ve used it before. What works well and what doesn’t?
  19. #269
    I used an off the shelf satin black from Arnold motor supply. I believe they said it was ppg. As far as correct, I'm not sure, but it looks good to me, and half the price. It is a single stage
  20. #270
    The lower black paint should be a satin/matte finish. You can spray a single stage urethane trim type paint that has been flattened when mixed. The other option is a bc/cc with the clear coat being flattened for the correct sheen. Either work well and dealer's choice. I personally would probably go single stage being that the color is just black.
  21. #271
    Nov 2011
    Alberta, Canada
    I had an opportunity to talk to my auto body supplier today. They recommended ditzler hot rod black. It’s a single stage satin black that should work well with my pace car. Now does anyone know where I should paint black on the inside of the doors? My pictures of the door jambs are pretty clear for me, I just don’t know if I can reach the doors in the snow covered shed.
    If someone has pictures it would be appreciated.
    Patrick
  22. #272
    Nov 2011
    Alberta, Canada
    Christmas came late this year. I purchased rear control arms and a big brake kit for the mustang. Unfortunately there are no instructions that came with the kit. In the meantime I’m installing some of it while I wait for the differential overhaul with new 3.55 gears.
    Some of the parts
Size:  84.1 KBName:  3974D534-BC8C-4F68-A72C-9D9DC2D012CB.jpg
Size:  77.1 KBName:  81437F96-B4A0-48E2-8245-51FDF80BCE73.jpg
  23. #273
    Nov 2011
    Alberta, Canada
    And now for some of the installation
Size:  92.9 KBName:  4AB37902-F17A-4A08-9D89-ED8A22882CF6.jpg
  24. #274
    Nov 2011
    Alberta, Canada
    Uh-oh.
  25. #275
    The tube on the steering column is a sleeve that will collapse slightly in an accident. You may need to use a piece of 2x4 and a rubber mallet, but the column should collapse down enough for the steering shaft to fit properly.
    Worse case, pull the column out and stand it on the steering wheel and work the sleeve. You can actually yank it off, clean the inside and the column then add a little grease and re-assemble. That should allow it to slide a bit easier. I do that to many of mine and will be doing the same to Erratic50's Saleen Clone column.
