Hi guys, I recently joined the site because I picked up a 84 5.0 5speed car. I'm looking to see what would be my best direction to go with this car. My plans with the car is to drive solely on the street, no track time. no racing. I want decent power and good drivability for driving on nice days with the top down. I plan on returning the ac to the car and getting it operational as well.
The car I bought was disassembled and does not currently run. It has an 89 roller engine installed. it was said to be the stock cam. I will confirm that before reassembling. The 89 engine is remanufactured and appears to be fresh, it has a roller cam and lifters. and e7te heads so I believe it to be an 87 up HO motor. very clean inside almost new. it has long tube headers, off road h and a flow master cat back. I received an offenhauser 360 split port single plane intake and the factory intake and factory carb. as well as many efi swap components I don't plan to use. I received the stock 84 long block, exhaust manifolds and all the emissions stuff that belongs to it.
here are the options I have
1. return 84 engine to the car and reassemble completely stock
2. install the correct distributer gear and cam eccentric on the 89 engine. leave the performance exhaust on the car and run the stock intake and carb(is the stock carb decent enough for this?)
3 same as #2 but buy a new 600 cfm holley and a better dual plane intake for street driving such as a edelbrock or a weiland.
