Results 1 to 6 of 6
    Default Distributor O-ring?
    My original '80 turbo engine is finally built, but the O-ring on my distributor is drier than a popcorn fart, so I'd like to replace it prior to installing it in the car. I cannot seem to find a listing or part number for it. Does anyone have the part number or source for this? Thanks in advance.
    Mike Rausch
    1979 Capri 2.3
    1980 Capri Turbo RS
    1980 Capri 2.3
    1980 Mustang 2.3
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    I got one of these ones: http://www.foxresto.com/1979-93-Must...-p/4279005.htm
    Honestly I cannot think why any similar sized neoprene o-ring wouldn't work.
    Darran
    Me either. I'd need to know the size and thickness, however. The original is far too brittle to try to remove without damage. I am wondering if the one listed will actually fit a 2.3? I got a fel-pro o-ring and it is too big.
    Mike Rausch
    1979 Capri 2.3
    1980 Capri Turbo RS
    1980 Capri 2.3
    1980 Mustang 2.3
    Take your distributor with you to your local parts store. Have them pull a replacement distributor for your 1980 Turbo. Compare the O ring to your distributor and O ring. If it looks correct, remove the o ring from the new distributor and then have them match it from there O ring assortment. Problem solved!
    Good Luck!
    82GTforME's is the same as the narrow 1/16" SECTION diameter
    1-9/16" nominal inner diameter, two thicknesses are 1/16 or 3/32.
    I-4, I-6,
    Fel-Pro - Distributor O-Ring
    Line: FEL | Part # 5511
    http://www.oreillyauto.com/site/c/de...patibilityTab_
    Prime it with Magnalube G
    http://www.magnalube.com/g-product-info
    There is a thicker one, Part # 13069, O-Ring Inside Diameter: 1.575 but it won't work as its too thick at 3/32".
    There is another interchange
    http://www.theoringstore.com/index.php?main_page=page_2
    -little late on this...Ford # is CODF-12143-A. they are obsolete, but there are a few dealers up in ur area that has some still in inventory....
    IF you cant find anything....
    '87 Turbo Coupe - 660 mile original
    '86 Turbo Coupe - 74k mile stripper
