Page 4 of 5 FirstFirst ... 2345 LastLast
Results 76 to 100 of 111
Thread: My 86 GT
  1. #76
    Oct 2004
    Ann Arbor MI
    Very nice Car and really like the photos of the work you are doing
  2. #77
    Quote Originally Posted by plumkrazy View Post
    Thank you very much!... like to document all the work I'm doing makes for a nice photo album later on...lol never know sometimes inspires others to do the same... It was the reason why I attempted this mod...
  3. #78
    Some more progress last night everything is back together...... Waiting for the sealer to cure out, then top off with Redline gear oil, ford racing friction modifier, bleed the rear brakes and then time for a shake down! Going to run it on the lift first to break in the C-Clip eliminators before taking it out...
  4. #79
  5. #80
    Almost there, it sure looks nice. I bet your dying to take it for a spin.
  6. #81
    Thank you! Yes I am! wife just asked please not to end up needing new rear tires ... I told her I need to make sure they are both spinning lol lol!!!!
  7. #82
    Default Back On The Road Again!
    OH YEAH I LOVE IT! All I can say is new tires if I keep that up lol! Ford Racing Carbon Fiber clutches are working! Phase one Completed.
    Breaking in the C-Clip bearings and clutches:
  8. #83
    Default Let's Begin Phase II
    So the next project is installing the Maximum Motorsports Panhard Bar...! Stay Tuned, never done this either
  9. #84
  10. #85
    Quote Originally Posted by Frankie L View Post
    Sweet!!!!
    Install is not too bad. Lots of measuring, checking, measuring, checking, and repeat until you know it's right! Good Luck!
  11. #86
    Sweet!!!!
    Ha Ha Ha that seems to be a common theme...Always great when you are in no rush and not depending on the car to be back on the road...Thank you!
  12. #87
    Oct 2014
    Calgary, Alberta, Canada
    Sweet!!!!
    That was probably the part that took the most work to get installed correctly out of the entire MM package I put on my car. But worth the effort.
  13. #88
    Did you happen to take any pictures of the part of the build?
  14. #89
    Oct 2014
    Just the end result.
    Most of the difficulty I had was getting the bracket to position correctly on the frame. I had trouble getting it to locate forward enough to the correct location as it ran into interference with the sub frames. Also had to fabricate shim plates to fit between the frame and the bracket mounts to get the angle correct. I believe these issues were mainly due to the car being a 79 and the slight differences to later years with the sub frames. In the end I settled for having it located just slightly further back than they specify and focused on having it aligned straight.
  15. #90
    Well that looks really good thank you...I don't have my sub frame connectors welded in, that will be next. I appreciate the advise...!
  16. #91
    Picked up a new Maximum Motorsports Strut Tower Brace & 4-Point K-Member brace, the guy never used them! Need to get busy, just have to find sometime lol...
  17. #92
    Default 4- Point K-Memeber
    got to work on the GT yesterday, the simplest mod yet took more time to get her on the lift than the install...!
  18. #93
    Default Shock Tower Brace installed...
    another night of wrenching... installed the M/M shock tower brace...when in fairly easy, had to move some stuff but well worth the effort. With the 4 point K-member and shock tower brace the car rides like it's on rails! I love these two last mods well worth the time, effort and the money! Love craigslist right now lol...
  19. #94
    Absolutely beautiful car man. Curious on what your wheel/tire set up is. Looks pretty wide on the rear.
  20. #95
    Quote Originally Posted by Sega2010 View Post
    Thank you...!
    17x9 front, 17x10 Cobra-R type wheels, the rear tire is only a 255/40..I'm going to run a 275/40 next and flip the quad shock if needed or I might go even larger and just remove the quad shock being the suspension upgrades that are done. I still have room in the rear on the inner side and outer with the 255/40 and once I install the Panhard Bar I will be able to adjust as needed...
  21. #96
    Welded in the full sub-frame and seat-bracket kit. All is primed and later will under coat and clean up the entire underneath, long night but well worth it! What a difference...!
  22. #97
  23. #98
    I’ve enjoyed this thread. Thanks for sharing! Nice ride!
  24. #99
    Thank you very much! I have enjoyed modifying it. Next should be the Pan-hard bar...
  25. #100
    FEP Member BrentX1's Avatar
    Dec 2008
    St. Charles Illinois
    Great thread. I enjoyed reading everything. Keep up the good work.
