I'm rebuilding the front end on my '84 LTD LX and decided to replace the rack as well. I've owned a lot of old Fords with manual steering and always liked it. So, why not stick a manual [non-power] rack in the LTD? Simplify things and save a few bucks. Manual racks for Fox bodies aren't exactly falling from the sky but I read that the more common Pinto/Mustang II racks are nearly identical. The only difference is that the Pinto rack mount bolts are spaced 16" apart where the Fox mounts are 15.5". With a set of offset bushings they drop right in.
The first step was acquiring a rack. A new Pinto rack from Rockauto was $103.78 after shipping. It seemed like a good deal at the time. As you will read in the following, this rack is only a bargain if you have the time and tools necessary to make it work.
The next step was finding a steering coupler. The input shaft on the manual rack is 9/16" 26-spline where the power rack is 3/4" 36-spline. I didn't want one that is held on with a set screw which pretty much leaves two choices; a stock Ford manual rag-joint or the solid shaft from Maximum Motorsports. This car is my daily driver, not a race car. I don't want to feel everything on the road so I went with the Ford coupler. The flange to adapt the stock rag joint to the manual shaft is Ford part# D9BZ-3A525-A. I found a NOS one on ebay for $129.11 after shipping. Probably could have found one cheaper if I had more time to look but I need to get this thing done this week while the kids are on spring break.
Unfortunately, the flange would not bolt to the input shaft on the new rack. The stock input shaft has a flat side so the coupler can only go on in one position. The new rack did not have a flat which lends me to believe it was originally intended for street rods and not a stock replacement. After grinding a flat in the new input shaft the coupler would slide on but the pinch bolt would not go in. That required grinding the groove in the shaft deeper where the bolt goes through.
I measured the tie rod length of the stock rack after pulling it out so I could set the tie rods on the new rack to be pretty close before it goes in. With the outer tie rods screwed in all the way the total length was still 1/2" too long. The new inner tie rods were the same length as the stock ones but they didn't thread them as far. I'm not sure if this is how all Pinto racks are or if it is just another blunder with this cheapy rack. As a solution, I cut 3/8" off the outer tie rods so they would screw in farther. Cutting them was easy. Grinding the ends so they were flush with the lock nuts took some time. I used a tool grinder but had to fiddle-fart with shims to actually get the end true because the bodies were not flat or straight. I would grind a little then test fit on the rack. If the lock nut didn't leave a mark all the way around then adjust shims and grind again.
With all that out of the way it's time to address the mounting issue. I bought some offset bushings from Summit Racing. They state that the bushings will allow you to mount a Fox rack into a Mustang II. It would stand to reason that if you turned the bushings the other way then they would allow mounting a Pinto/Mustang II rack into a Fox. The bushings came with center sleeves and offset washers. The sleeves are for 16mm bolts and the washers are for 12mm bolts. My car has the 16mm bolts so I had to chuck up the washers in a four-jaw on the lathe and bore them out to 16mm. I didn't understand why they had mismatched parts until I went to bolt the rack into the car. The bushings themselves only change the mounting width by 5/16" not the necessary 1/2". Summit expects you to use 12mm bolts in the 16mm ID sleeves to make up the difference! To try and make it fit with 16mm bolts I made some offset sleeves to go in the offset bushings.
That reduced the distance by 1/8" overall but that still leaves me at 15-9/16" center to center. I was up half the night making the sleeves so I haven't tried fitting it yet. Hopefully there is enough slop in the K-member holes for it to work.
