I have a factory cylinder that is leaking at the case seal at the top. I just made the mistake of buying a set used from the last place I will ever order a part from again.....of course they were junk. I wanted an OEM cylinder so I could replace the one side and not have to worry out replacing the pair to match with after market cylinders. So for those who have replaced their cylinders, with aftermarket cylinders, any brand/supplier recommendations?. Also how many years have you had them installed, any issues.?. Last did the new aftermarket cylinders, eliminate the issue with the top header dropping/slamming onto the header when closing. (an issue that seemed to be there from new on all cars that I have seen....)
thanks!
