Results 1 to 16 of 16
    Jan 2003
    Muskegon (Power Tour stop!)MI
    Default GT40 2 bar heads...???
    Anyone have any experience with the GT40 2 bar heads? Casting number is F3JE. From what I have learned is that these are a marine head. What does that exactly mean I'm not sure yet? Just trying to gather some more info on these and if they worthwhile to use in a car application.
    Thanks,
    Zen
    '86 GT - weekend driver
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    FEP Member Mgino757's Avatar
    Jan 2011
    Virginia Beach, VA
    Got pics?
    Same size valve as all other GT-40 heads (not GT-40P heads) but have the largest combustion chamber of all GT-40 and GT-40P heads. Compression ratio will drop some but not as low as 1979-84/85 CFI.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Jan 2003
    That's some of the info I got from Ford Racing (Performance) also. I think they told me 69cc, approx. compression ratio of 8.2 ????
    Does anybody run these on a street car? Are they worthless for a street performance application?
    Will try to get some pics up...
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    Jul 2010
    Houston (Clear Lake), Texas
    They would probably make a good candidate for a forced induction power plant...
    HAD
    HAVE
    I think spec is 66-69 cc so 69cc is on the high side of the variance. Not a great choice for natural aspiration and flat or dished pistons. I'm with bwguardian...would be better for forced induction where you'd want lower static CR.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    FEP Senior Member BlackMamba's Avatar
    Aug 2012
    Los Angeles, CA
    Quote Originally Posted by ZEN50 View Post
    Thanks,
    Zen
    I have the marine gt40 heads too but they have the 3 bars and the port for the thermactor/crossover tube in the back.
    I'll try and get the casting number later tonight.
    Current Cars:
    1979 Mustang Ghia Coupe 5.0 3J Bright Blue
    1984 GT T top 306 5 speed "Black Mamba"
    1986 Saleen Black with Silver Stripes 86#009
    1986 Mustang GT Medium Canyon Red 5 speed 5.0
    1999 Mustang GT Convertible 35th anniversary 69K miles.
    2002 Nissan Maxima 6 Speed "Daily Driver"
    2009 Corvette 6 speed LS3
    1998 Cobra 71k miles Canary Yellow "Nana" SOLD
    Jan 2003
    Yeah, that was pretty much my understanding of it also. Could the heads be machined for more compression or is that just opening up a can of new problems?
    I guess the search is on for some new heads!
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    You could cut them to drop the cc down some but not sure if you could cut enough to make a difference. Cut too much off and then you have trouble getting the intake to align and seal properly. The only thing the "J" heads have going for them is larger valves and improved flow over earlier late model factory heads. Other GT-40 heads are better only because they have smaller chambers for a bump in CR.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Aug 2012
    Los Angeles, CA
    double post
    Current Cars:
    Jan 2003
    II bar pic.....Name:  2BAR.jpg
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    Jan 2003
    lansing, mi
    Those would be good heads for someone looking to do a budget 351w build, will net around 10:1 compression there. Someone would probably trade you their GT40s for them.
    Cale
    Jan 2003
    Sounds good to me Cale, get a hold of me
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    Jan 2003
    lansing, mi
    Haha sorry Zen I guess it does kind of sound like I was hinting at something. Did you end up getting some heads off of Mitch?
    Cale
    Jan 2003
    Yeah, sure did. Met him in Lansing yesterday. Was thinking about contacting you but figured you were probably working.
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    Jan 2003
    lansing, mi
    Ah man! I got some parts here with your name on 'em too!
    I'm glad you got some heads better suited to your needs.
    Cale
