How to do it?
First you need 4x6" Halogen semi sealed H4 or H7 headlamp bulbs in the daimond crystal clear set.
Or these H7 bulb items
Then buy the HID upgrade.
Or shop some place like this
http://www.blindinghid.com/b.php?bul...tang&year=1981
Remember, you can't wire in series, and you have to use an HID ballast box. Install ballast assembly into headlight housing (use double sided tape/velcro or screw in place).
The normal
http://www.prostreetlighting.com/pro...N-KIT-4pc.html
HID lights are not compatible or legal in the US according to the DOT requirements. In Canada, you'll get away with H4's with replaceable bulbs, just like I will in New Zealand. If your in France, you can run H4 lamps off a Renault A310, and get the best lighting money can buy. It won't be US legal though.
Please note all HID retro-fits are technically illegal through-out all of the US, Canada, the EU, Australia.
See
http://www.danielsternlighting.com/t...nversions.html
That doesn't mean you can't do the HID swap, its your car, but there is no headlamp levelling circuit to work in with the 6-1/2" quad lamps. The HID lamps
must be adjustable for vehicle ride, and the bare minimum requirement is a Dorman's generic $69 Aftermarket Replacement (AM-AutoParts) # 924-755 as used on the HID/Xenon Lamped Mazda 6, RX-8, Toyota Prius, Tacoma, Lexus post 1998 Lexus LS400 and all LX470's, IS300, ES300, ES330, RX330, RX350, RX400h.
That system uses one rear offside sensor on front drive cars like GS or ES330's, while a rear drive specialty like the RX-8 or rear drive Lexus LS430 has two offsides front and rear. An LX 470 SUV has four. Its hooked to the suspension by a rod end, and then the front lamp housing has to get a motorized adaptor to level the front lamps based on ohms resistance from the rear sensor. At the very least, one offside leveling sensor at the back is just a strain gage, and as the suspension is loaded or the car accelerates or banks hard through a corner, the ohm rate goes up, and the headlamps are angled downward to avoid dazzling the on comming driver.
Hella and Siemen have there own retro fit for German cars that works the same way, but the Fox Four Eyes have no provision for a level sensor at the back, nor a motorized headlamp leveling system, and although you can fit HID's easily to a replaceable bulb H4 non sealed beam lamp, they
aren't compatiable with the frosted glass pattern H4 lenses have.
The whole idea is to respect the on coming driver.
Going back a step, HID's are very efficient, and setting them up is just a case of finding any HID specialist, and having them fit HID's with the right lenses and connectors. I don't wanna be a kill joy, but I've spent 14 years doing state highway road inspections, and when our Kiwi market Mitsubishi L300 and JDM Import Delica forward control vans hit town with these lights in 1993, the high beams could blind drivers, the low beams could too because they had no leveling device. Then the 94 BMW 7 series got them, and then the 98 LS400 Lexus. The Germans and JDM cars got headlamp leveling hardware to go with the bulbs, and the systems started working quite well. Unfortunately, even the headlamp levelling hardware, especially the suspension strain gages, are not reliable, and so the new replacements sell for a tenth of the prie of the orginal Lexus items to ensure the HID systems are safe.
Untill there is a retro fit quad 6-1/2" headlamp levelling system, HID's will remain illegal.
