Results 1 to 24 of 24
    Default 1979 Mustang door tag
Size:  66.6 KBName:  IMG_0611.jpg
    Could someone help in decoding this door tag. It's a 79 2.3t coupe.
    Thank you
    Can you get to the buck tag for this car, or take a pic of it? How many miles on the odometer? does it have any of the following options?
    console
    color-keyed seat belts (same color as interior)
    door mirror with or without remote control
    engine block immersion heater
    factory front speakers: single speaker (in center of dash) or dual speakers (one each corner)
    factory wheels: steel wheels with turbine covers, wire covers, or center caps with trim rings, or 14" 16-slot aluminum wheels, or metric TRX aluminum wheels
    four-way manual driver seat
    interval windshield wipers (twist knob on end of wiper stalk for wiper time delay)
    leather-wrapped steering wheel
    light group (light under hood, light in glove box, light in front ash tray, light in trunk, pivoting map light)
    lower bodyside protection
    lower tu-tone paint treatment
    power brakes
    power door locks
    power steering
    rocker panel moldings
    tilt steering wheel
    tinted glass - complete (tinted windshield and slight tint to side and rear glass)
    tinted windshield (only)
    trunk light (only)
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Mar 2013
    DENVER CO, the 303
    Wow car has 76 dso, from denver interesting, very cool car and great color combo!!
    I'll get a picture of the buck tag later on today. The odometer rolled over so my guess is 113000 as it had 79000 when registered in 08 according to the title. It looks like a bare bones car with no passenger side mirror, no interior lighting, no intermittent wipers, no center counsel etc. it does have a 2.3t and the 8000rpm tach gauge cluster.
    [attach]110679
    VIN
    9 = 1979 model year
    R = San Jose Assembly
    02 = Mustang 2-dr coupe
    W = turbocharged 2.3L engine
    154898 = 54,898th 1979 Ford scheduled for production at San Jose Assembly
    Door Tag
    Date - 04-79 = April 1979 scheduled build
    GVWR - 3745 lb/1698 kg = gross vehicle weight rating
    Front GAWR 1945 lb/882 kg = front gross axle weight rating
    Rear GAWR 1820 lb/825 kg = rear gross axle weight rating
    F0079 = 79 lbs front accessory reserve load
    R0130 = 130 lbs rear accessory reserve load
    Exterior Paint Colors - 83 WT = Light Chamois paint (83) and and Lugano grain Chamois vinyl roof (WT)
    DSO - 76 = Denver district sales office
    Body - 66B = Mustang 2-dr coupe
    VR - WT = Lugano grain vinyl roof (W), Chamois vinyl roof color (T)
    Int Trim - AT = all vinyl seating, high-back front buckles (A), Chamois interior trim color (T)
    A/C - A = air conditioner
    R - 2 = AM radio
    S - [blank] = no sunroof
    Ax - F = 3.45:1 axle ratio, non-locking differential
    Tr - 6 = Borg Warner 4-speed manual transmission
    YY = front springs
    MM = rear springs
    Buck Tag
    8
    83X = Light Chamois exterior paint color
    T = Chamois interior trim color
    W6 = turbocharged 2.3L engine (W), Borg Warner 4-speed manual transmission (6)
    A = manual air conditioner
    9
    Q
    S
    L
    B
    C
    V CMOIS = Chamois vinyl roof
    02B = Mustang 2-dr coupe
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Thanks if decoding the buck tag. I'm hoping the build sheet is under the carpet. I'll post pictures of it if found. The doesn't seem to have many options though.
    Did you find a build sheet?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Haven't found the build sheet yet. I peeked under the carpet, but found nothing. I'll be moving soon so both my pace car and coupe will be at the same location so this will make life easier. Indoors as well. It's a tad bit hot here right now in Az too spend anytime outdoors. Other than the drive train and suspension I may bring it back to mostly original including the vinyl top and chamois interior. Time will tell.
    Here is what was left of the build sheet. Not sure where the left 1/3 is. I find it interesting that the 73 written on the bottom of the page is also written on the back of my car where the license plate goes.
    Spent 7 hours last Sunday working on the paint. Looks like it came out pretty nice. Looking for a new chamois top. No luck yet on a place to purchase one. If anyone knows of a place to get one it would be much appreciated. I checked SMS and one other place mentioned by another member mentioned without success.
    I have decided to try and keep the car as stock looking as possible with the chamois interior and all. It will also stay a 2.3t car. Not sure which 2.3 will end up in it, but probably this one. Name:  IMG_0199.jpg
    Build Sheet
    Line A
    Rotations Number [?] = unknown body & paint rotations number
    Line - Z = Mustang model line
    Serial Number - 9F02W154898 = [VIN decoded above]
    Body Type - 66B = Mustang 2-dr coupe
    Body, Toof, Type = [W?] = Lugano grain vinyl roof
    Body, Toof, Color = [T?] = Chamois vinyl roof color
    Body, Tops, Roof - [blank] = no sunroof
    Ext, Paint, Body - 83 = Light Chamois exterior paint color
    Ext, Paint, Accent - [blank] = no accent paint
    Int, Trim - AT = vinyl seating, high-back front buckets (A) Chamois interior trim color (T)
    Int, Trim, Dev - [blank] = no interior trim deviation
    Inst BD - T = Chamois instrument panel color
    Ext, Tutone - [blank] = no tu-tone paint
    Type of Order - C = Fleet order
    Region & District - 76 = Denver district sales office
    Line B
    Emission Control - [?] = unknown if equipped with special emissions package or not
    Imm Block Heater - [?] = unknown if equipped with engine block immersion heater or not
    Engine, Tag Number - [?] = unknown engine tag number
    Transmission, Code - 6 = Borg Warner 4-speed transmission
    Transmission, Part Number - [?] = unknown transmission part number
    Line C
    Air Condition - M = manual air conditioner
    Line D
    Electrical, Wipers - [blank] = no interval windshield wipers
    Electrical, Defogger - [blank] = no electric rear window defroster
    Electrical, Audio, Radio - A = AM radio
    Electrical, Audio, Spkrs - [?] = unknown number of speaker(s)
    Electrical, Lights, Light Group - [?] = unknown if equipped with light group or not
    Seats, Power - [blank] = no 4-way adjustable driver seat
    Seats, Bucket/Split Bench - 2 = bucket seating
    Belts, Type - S = standard seats belts
    Belts, Color - A = Black seat belt color
    Carpet/Mats - [blank] = no floor mats
    Console - C = console
    Groups, Decor, Interior - [blank] = no interior decor group
    Groups, Decor, Exterior - E = exterior decor group
    Mirror, Inside - [blank] = no passenger side vanity mirror
    Line E
    Battery - [?] = unknown battery type
    Driveline, Speed-O, Metric - [blank] = no special speedometer
    Driveline, Rear Axle, Tag Number - 284B = 3.45:1 axle ratio, conventional (non-locking) differential
    Suspension, Springs, Front, Left - YEL = 'Y' front left spring code
    Suspension, Springs, Front, Right - YEL = 'Y' front right spring code
    Suspension, Springs, Rear, Left - PEV = 'M' rear left spring code
    Suspension, Springs, Rear, Right - PEV = 'M' rear right spring code
    Line F
    Wheel Area, Wheels Covers - [?] = unknown wheel covers
    Wheel Area, Wheels, Code 1/2 - [?] = unknown wheels
    Tires, Size - B 83 = B-load-rating, bias-ply, 78% aspect ratio, 13-inch
    Tires, Contruct - B = bias ply tires
    Tires, Color - W = white sidewalls
    Tires, Spare - M = mini spare
    Tires, Quantity - 4 = four full size tires
    Front End, Steering Wheel/Column, Wheel Color - T = Caramel steering wheel and steering column cover
    Front End, Steering Wheel/Column, Col. - T = tilt steering wheel
    Frt License Plate Bracket - X = front license plate bracket
    Line G
    Mouldings, Rocker - B = black rocker panel mouldings
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Thanks for decoding the buildsheet.
    Just an idea, try calling a local Cadillac or lincoln dealer to see who they send cars to for vinyl roof installs. Maybe they can match something up for you.
    Sep 2010
    Lexington, MA
    Quote Originally Posted by Lowetlx View Post
    X2 for the vinyl roof install.
    This one is really clean; http://www.ebay.com/itm/1979-Ford-Mu...EAAOSwK-pZsZS8
    Looks nice. Mine was only a coupe hundred bucks and some time though.
    FEP Super Member roush235's Avatar
    Jul 2005
    Lebanon, TN
    That chamois car at Streetside Classics is a stunner. Very few early four eyes are that clean and (mostly) stock and unrestored, Pace Cars excluded. That car has lived a pampered life. And wow, what a price.
    Bob in Lebanon, TN
    79 original owner six cylinder coupe
    MCA Gold Card judge for 3rd Generation cars
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Nice find! Good luck with everything!
    Odd someone put dual exhaust tips on the car at some point. Where did you find the build sheet? Both of our San Jose 79's were under the driver's seat tucked in a spring.
    It was stuck to the bottom side of the back seat. There was a white pad stuck between it and the floor. That's why I missed it the first time. The car has duel exhaust because prior to me purchasing the car it had a V8 in it.
