So, I got a scanner, used it on my 86 GT, a few codes popped up (KOER) all for air thermactor flow and 32-EGR insufficient flow. Concentrating on EGR code 34. This is what I can tell, after each changes made below I reran the KEOR scan but still get a 34. Engine runs fine, but I heard an improper functioning EGR can cause MPG issues and cause it to run rich.
1. Swapped EGR valves, had an extra one in garage in really good shape. Also cleaned the original one and tried it again.
2. Operated EGR valve with vacuum pump while engine running to 5 lbs and engine stuttered and died instantly so I know the valves are not blocked and diaphram works. Also held 5 lbs and didnt bleed off.
3. Checked all vacuum lines and found a bad route / blugged port that feeds vacuum to the passenger solenoids. Fixed that, same codes.
4. Checked 12v at the egr regulator solenoid, when plugged in 12v to both wires.
5. decided the solenoid wasnt working, replaced it with a new one.
5. Using a wire diagram found the wire lead that operated the solenoid, grounded it while engine running, it sent vac to the EGR valve and the engine died.
6. Check and cleaned ECU ground wire.
So, the EGR system functions properly from the solenoid acitvating, sending vac to valve and the valve operates as it should. My next thought was the ECU isn't sending the signal, but the wires are all in good shape. What am I missing? The code 34 from the book, means "lack of EGR air flow" not EGR error, or not opening at all.
Any help appreciated! Thanks all,
