Question about black rockers, specifically for '83, but interested in other years as well; were they available on any model? GT specific? My '83 GT has/had them, but I'm curious if they found on any other trim levels.
My first car was an 83 Mustang GL that had the black rockers. Also on the SVO's just shorter because of the rear spats. Not sure on the rest.
86' SVO 1C # 17 of 3379 86's #6475 of 9837
86' SVO 1C #497 of 3379 86's #6955 of 9837
84' GT Turbo #4 of 3241 GT Turbo HB's #560 of 3935
87' Thunderbird TC 1 of 10
http://www.foureyedpride.com/content...e-of-the-Month
Ok, this question will show the true level of my ignorance; I'm actually not sure I understand what this option really is. My initial assumption was this is two tone paint, with the area below the body moulding painted black. However, further investigation makes me believe it's only the actual rocker panels below the door sills, painted the same satin black as the other trim.
So, experts, which is it? Please educate this ignorant old fool.
For Salted Road states with certian DSO's, there was a Road Abrasion Package and rocker paint are different, but look the same...
1982-84 GT/Turbo GT = paint
all others, including SVO = molding
Not sure about 1982-83 RS/Turbo RS but I know 1984 had tri-color stripes (silver, yellow, orange) instead.
1983 GT/Turbo GT was the only year to have a buck tag code for the painted rocker, even on units with lower tu-tone.
There was also a "bright" rocker molding and it had a code every year it was available.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Ah, ok... So lower two tone is separate from the black rocker? Two tone would have a double paint code?
My paint code is 9D Polar White, on both the door and buck tags, and the buck tag shows BR for the rockers.
Yup, they look the same, but the base of the underneath of the car is coated with whatever they did to cover it.
A gray undersealant, basically.
A non Road Abrasion car.
Line D in build sheet.
On the Buck Tag, no RA code.
http://vb.foureyedpride.com/showthre...Sheet-and-Tags
Canadian, RA code "abbrasion" as an extra in the build and buck tag details...
http://vb.foureyedpride.com/showthre...-and-door-tags
And the kicker... Canadians got emissions reject Turbo Carb cars, and everything Turbo Cobra lookes like it had the RA package
http://vb.foureyedpride.com/showthre...O-CAPRIS/page2
Yeah, I am familiar with road abrasion coatings. My car does not have that option. My question is specifically about two tone paint vs black rocker.
Tu-tone paint cars had two paint codes on the door tag, except 1979, buck tag, build sheet, and owner card. Then 1983 GT/Turbo GT also had BR code.
Example: http://vb.foureyedpride.com/showthread.php?81218
From 1979 through 1984 lower tu-tone cars had 1C on door tag, except 1979, build sheet, and owner card, and TT on buck tag.
In 1985 the code was XP on door/build/owner and TT on buck.
In 1986 the code was 71 on door/build/owner and TT on buck.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Got it, thanks! So my car is mono tone white with black rocker panels. Excellent!
Oh, and all these questions stem from the fact that my car currently wears a very tired medium red repaint, with black rattle can highlights...
VIN
1FA = Ford vehicle manufactured in USA by Ford Motor Company
B = active belts, no airbags
P = passenger car
28 = Mustang 3-dr hatchback
F = H.O. 5.0L V8 engine
2 = VIN check digit
D = 1983 model year
F = Dearborn Assembly
122585 = 22,585th 1983 Ford scheduled for production at Dearborn Assembly
Door Tag
Date - 10/82 = October 1982 scheduled build
GVWR - 3950 lb/1791 kg
Front GAWR - 2108 lb/956 kg
Rear GAWR - 1910 lb/866 kg
F0110 = 110 lbs front accessory reserve load
R0107 = 107 rear accessory reserve load
Exterior Paint Colors - 9D = Polar White
DSO - 17 = Washington (D.C.) district sales office
Body - 61B = Mustang 3-dr hatchback
Int Trim - FD = cloth & vinyl seating, low-back front buckets (F), Medium Red interior color (D)
A/C - A = air conditioner
R - 3 = AM/FM monaural radio
S - [blank] = no sunroof, no T-roof
Ax - Z = 3.08:1 axle ratio, Traction-Lok differential
Tr - 4 = manual overdrive transmission (Tremec 4-speed 'SROD')
KK = front springs
HH = rear springs
Buck Tag
MUSTANG = Mustang model line
0429 = body & paint rotations #0429
9D = Polar White exterior paint color
DF
ST
AC = manual air conditioner
04 = YES rear defrost, YES rear wing
HB = heated backlite (rear defrost)
GT = GT model/trim level
BR = black rocker panel
MOD = manual overdrive transmission (Tremec 4-speed 'SROD')
03 = rear-facing non-functional hood scoop
-D = Medium Red interior trim color
NLR
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
