Results 1 to 22 of 22
    FEP Senior Member ddx77's Avatar
    Jul 2011
    Fort Lauderdale, FL
    Default Evapo-rust - works great.
    Been trying to clean up my engine compartment a bit. Figured I would try Vapo Rust before Using por-15 and painting everything that's rusty.
    Man I'm impressed, I though my belt tensioner pulley was shot. It came out amazing. Before and after.
    I may just hit it with a flat clear coat now.
    FEP Senior Member 9DBlackMagic's Avatar
    Sep 2006
    Antioch, California
    What the product look like cause I need to do some as well.
    ~LES~
    157 HP @ 4200 RPM
    240 ft/lb @ 2400 RPM
    "Yeah Baby Feel That Pure Power"
    Capri:
    Is a Mustang With Hips And Class
    Jul 2011
    Fort Lauderdale, FL
    Default Vapo-rust - works great.
    Quote Originally Posted by 9DBlackMagic View Post
    I know there are other similar products, but I think I may have seen a thread from another FEP member recommending it as well.
    Jan 2006
    Western MA
    I've been using it on smaller parts and it does work good. Takes a bit of time depending on how much rust is present.
    Jul 2011
    Fort Lauderdale, FL
    Yes for rusty bolts, overnight works best for sure. The belt tensioner I soaked standing up in a small container, only 1/4" deep so the liquid didn't hit the bearing. I kept rotating it throughout the day. I also used a small wire brush to work it in a bit. So like 6 hours. It works well if you're patient.
    Jul 2009
    Chicago, south subs
    My local Harbor Freight sells Evapo-Rust
    I've used the wd40 product on my project. It does a pretty good job too. Overnight soak at least, sometimes change the juice and do it again (I'm in the rust belt). I've used it on nuts n bolts, brake and fuel line brackets etc. You can use it on bigger stuff if you soak rags of it then wrap up the part and wrap in plastic. Then a good soap and water bath, and finish it off with paint or a good soak of regular wd40. I've been pretty impressed with the results. Downside is you WILL see what's under the rust. Be prepared for that
    FEP Supporter cmgramza's Avatar
    Dec 2010
    Arlington, Va
    Will it attack rust and paint, or just rust, and leave a painted surface alone?....
    Have
    86 Coupe LX Conversion 5.0 5spd
    70 Mustang Conv. My 1st car. Still have it.
    70 Ranchero 302 Auto
    07 Focus daily driver
    Totaled
    70 Ranchero 351C Auto
    85 Coupe 1 of 62 Sand Beige
    Jul 2009
    Chicago, south subs
    It's reusable too.
    I bought some based on the recommendations here. Now I just need it to warm up enough to use it. Directions say use at 65 degrees minimum. Anyone use it at lower temps?
    Jess
    Previously owned;
    Jul 2011
    Fort Lauderdale, FL
    Quote Originally Posted by cmgramza View Post
    Seems to remove the rust off of black painted bolts and leave the paint. If the rust has gone through the paint, obviously it's gone. The inside of that tensioner I did is black and it didn't hurt it at all.
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    It's reusable too.
    I've used "Metal Rescue" (same stuff as EvapoRust) over and over until there is no more chemical reaction left. It turns from clear to black as it gets spent. I do find it a little pricey for what it is, but it is what it is. I buy it because it works well!
    One thing I noticed is that it removes Cadmium coatings and Parkerized coatings from items. That can be good or bad depending...Paint, as said will not be affected to any degree that I've seen.
    Darran
    Sep 2006
    Antioch, California
    Thanks ddx77
    ~LES~
    157 HP @ 4200 RPM
    Capri:
    FEP Super Member 79mustangcobra's Avatar
    Dec 2002
    Greenville, SC
    Love Evapo-rust! I use it all the time for used parts, etc.
    1979 Mustang Cobra 5.0
    2P Red and 1C Black
    Stock never goes out of style
    Proverbs 3:5-6
    My Mustang Story
    FEP Member Prestige Auto Body's Avatar
    Sep 2010
    Southern Indiana, outside of Louisville KY
    When I was restoring my Pace Car last summer I bought the small parts washer from Harbor Freight and used it for my Evapo-Rust cleaning tank.
    I think circulating the solution with the pump in the washer helped to speed up the process.
    I went through at least 3 of the 5 gallon containers over the 6 months time......
    I get the same results from vinegar.
    Brian R. of Michigan
    83 TBird 5.0
    88 Ranger 2.3t
    Oct 2004
    Ann Arbor MI
    Quote Originally Posted by deathbypsi View Post
    Yep my buddy has a 5gallon bucket full of Apple Vinegar that always has things soaking.
    Oct 2004
    Ann Arbor MI
    Nov 2014
    Grand Rapids, Mi
    I read on another forum once, a guy who's truck had a rusty lower door shell. He built a bag around the lower part of the door, soaked the door in it, and later pulled it out and it looked brand new. Impressive stuff.
    Sweet thanks for the info.
    1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 10131mph.
    I second the vinegar. I just dumped out half a bucket of old vinegar I've been using for a few months. I've got some parts soaking in a fresh batch, now. Works like a charm and I'm guessing a little cheaper. Just need to rinse the part well and coat as soon as possible to keep it from rusting again. But even if it does re-develop a layer of rust, you can simply soak it for an hour or two and it's gone again.
    Jan 2006
    Western MA
    A while back I watched this video, while not scientific it was interesting. It compares Evapo-Rust with Metal Rescue, Vinegar, and Coke (soda).
    https://youtu.be/DZVdkLWAurE
