Hi,
Today I've pulled the aluminium bumpers off my parts car and compared them with the steel ones of my Ghia, and used a scale to compare the weights (probably not the most accurate but it does the job). Here are the results :
Front steel (with turn signals and housings) - 15.5Kg 34.2lbs :
Front aluminium (with turn signals and housings) - 6.5Kg 14.3lbs :
Rear steel - 14.5Kg 32lbs :
Rear aluminium - 6Kg 13.2lbs :
That's a major difference, around 2/5th of the weight of the steel bumpers.
Hope it helps
