Results 1 to 4 of 4
    Default Wideband power source
    I'm adding an Innovate MTX-L and a Vacuum gauge in place of the factory "information panel/clock" panel, and am looking for recommendations on where to source power from. The connectors from the (now) removed information/clock panel have several 12V switched sources, but will they be too "busy" to get a steady 12V supply? I have upgraded to the 3g alternator with internal voltage regulator which I hear provides a more stable signal.
    Is there a better place?
    Radio power????
    85GT with a NEAR stock 88 motor. 1988 EEC 4 SD conversion. Built AOD trans. & converter. Leaving at 1,000 rpm- 1.876-60', 13.62 @ 99.40 MPH. On 235/ 60-15 ET Streets.
    https://www.facebook.com/groups/FOXBODYFLEAMARKET/
    I've read that the radio power is not good for wideband sensors due to the varying current draw affecting the reference signal. I was looking more for a power supply that would keep a steady 12V with little variance.
    FEP Member Mgino757's Avatar
    Jan 2011
    Virginia Beach, VA
    On mine, I used the cigarette lighter as power and wired an adapter to the power wires of my MTX-L. However, I would recommend against it if you plan on running it full time while driving. I run mine only long enough to tune the carb and unplug it when I'm done. I install it when I tune and uninstall when I'm done.
    1985 Mustang GT conv. modified 4180C, Weiand Street Warrior intake manifold, equal length headers, true dual exhaust, 3.55:1 8.8'' rear end, 180* thermostat, Ford Racing 10.5" clutch. Garage dweller.
    1998 Mustang GT auto. Stock and slow daily driver.
    1996 Thunderbird LX 4.6L V8. Wrecked, drag racing in heaven. RIP Oct 1995-March 24, 2016.
