Results 1 to 25 of 38
    Default Is my engine stock?
    This is my first post and I am a complete noobie to thsese cars so sorry for the silly question. Anyway I recently bought a 1985 Mercury Capri RS with a 5l 5 speed and am very happy with it, however the engine dosnt look like any Foxbody engine I have seen. I am hoping one of you would be able to tell if it is the same engine it came with from the factory? Name:  IMG_0160.jpg
    I can't speak to your specific car of course but that looks somewhat like a 1985 5.0 HO engine based on the picture. A true '85 5.0 engine would have had an aluminum intake with the Ford logo stamped in it. That may be the correct intake only painted blue, I can't say. It has had the smog pump removed and it did not come with those electric fans. It would have had a clutch-type fan and a different dual-snorkel air cleaner assembly on it. Also the engine would not have been blue from the factory so either someone has painted it in place or it has been rebuilt/replaced at some point. Your car appears to not have AC and that front engine dress would be correct for a car without AC as well. The valve covers would also be correct.
    John Adams
    July 7, 1775
    Thank you very much! I have also found this stamp on the manifold although I doubt ot helps much.
    Jan 2011
    Vancouver BC Canada
    Correct intake , wrong carb
    As well, somebody put an Edelbrock/Carter carburetor on it.
    Jul 2010
    Houston (Clear Lake), Texas
    There should be some numbers on that pad on the other side of the block. Those numbers will have some of the same information within the v.i.n. if you are wanting to know if it could be an original engine block to the car.
    HAD
    HAVE
    I cant find any numbers on the other side besides an R stamped behind the valve cover.
    I have just found paper work from the previous owner who had it in for a wheel alignment, balancing and checking the timing. It lists the engine as a 5.0l V8 M OHV 4bbl but im not sure if that would just be going off the VIN number or not?
    Engine height looks correct for an 8.2 deck height block which is factory - motors like the 302 and 289 were 8.2.
    Modifications are very popular on Foxbody Mustangs and Capris. Impossible to know what it is internally without tearing it down and inspecting everything.
    You could pull a valve valve cover and see if there is evidence of aftermarket rockers, or springs, etc.
    If it's not broke, don't fix it. 302's usually run great with a properly sized and jetted AFB/Edelbrock carb.
    Ok, thanks for the input. The carb is a weber BTW although that probably dosn't matter.
    Quote Originally Posted by 85CapriRS View Post
    ... however the engine dosnt look like any Foxbody engine I have seen....
    What about this small block Ford V8 does not look like any other Fox body engine you've seen? If you're used to looking at all the who-haw atop of the EFI engines, then I get it. Otherwise, the engine in your first photo up there is run-of-the-mill SBF fare.
    I used to know a guy who had an 84 Mustang with a 5.0l however after looking at some pictures on the internet it was probably an EFI. My cousin also owns a fox however his engine looks nothing like mine and after asking he said it was heavily modded. I knew it was a Ford 302 but I wasnt sure if it was a mustang/capri 302 if that makes sense. I also didn't know if there would be a way of identifying it as being the original engine from the car like a VIN number.
    I believe Weber was contracted out to make the AFB style carb for Carter and then Edelbrock. Most everyone identifies them as the Carter AFB.
    That makes sense. Like I said I'm a complete novice when it comes to these cars and their aftermarket parts.
    Jan 2003
    lansing, mi
    That is a non-a/c car from the factory. The heater hoses would have come out of the firewall behind the intake manifold if it had a/c. This is good because it makes changing a failed heater core a much easier job. That intake manifold has likely been off that engine as well - that is not a factory bolt in the picture. The engine code is the 8th character in your VIN, it tells you what engine the car left the assembly line with.
    Cale
    Quote Originally Posted by cb84capri View Post
    Cale
    I have the VIN number for the car and after typing it in to a decoder everything checks out. Its a 1985 Capri RS with a 5.0l H.O. 4bbl. I was hoping to find a VIN number on the block its self although I would probably have to take out the motor to see it, right?
    Thanks!
    Aug 2005
    Plymouth, Ma.
    The vin number should be right at the back of the intake manifold ON TOP OF THE BLOCK. you should see a pad on the drivers side with some numbers stamped in them. You may need to clean the pad with some sandpaper to read the numbers.
    85 G.T. All motor
    337 c.i.d 11.44-120 mph
    1984 G.T. (Daughters car)
    Quote Originally Posted by 306gt View Post
    Alright I will check when I get home. I also looked up that number on the manifold and it looks like its an 1984. Would that have something to do with what was mentioned above about the manifold's bolt? Or would it have been common to put an 84 manifold on later cars?
    Jul 2010
    This is what I was talking about in my earlier post. It will not have the entire v.i.n. on the pad, but the numbers should match part of the v.i.n.
    Ford produced parts and implemented numbers for recognition. So the E4...1984...part number was utilized for several makes and/or year models.
    HAD
    HAVE
    Just checked and still cant find anything. I cant even find the flat pad the numbers would be on. Thanks for all the help though! I think I would probably have to take out the motor to see it.
    This is all I can see looking behind it.
    It's on the flat part of the block between the center of the bellhousing, the other numbers are usually right near the starter on a flat spot between freeze plugs if I remember right.
    Bell housing shouldn't be blue. I'd say its pretty likely the engine and trans have been out before, but it's a 30+ year old car and mustang get beat on and modified alot.
    This is on the block just above the bell housing but I still cant see or feel any numbers.
    Hmmm, your engine is the same color as BTD's 83 engine.
    From personal experience, its like looking for chassis buck codes or finding the chassis catwalk horns; you have to look in the right place. A miss is truly a mile...you might as well be in Peru...
    Quote Originally Posted by awakened View Post
    I took the intake off of my 86 GT convertible and when I looked at the spot where I thought the VIN number should be on the block I see this. A partial "1" and a "9". I do not have a "9" or a "6" in my VIN.
    Attachment 96956
    Does anyone know what this means? Is this a replacement block? Why isn't there at least the wrong VIN there? Assuming it's not the original block, how would I determine what it is or what it was from?
    Sent from my SAMSUNG-SM-N915A using Tapatalk
    awakened was expection some combination of his VIN, which should have been M 271250 in his case.
    First, use some solvent and a tooth brush to clear 32 years of dirt and grime from the exact spot.
    Sometimes, the indentations require Magnaflux to determine, or dye penetrate, or blacklight or even X ray.
    There is a date code as well as the partial VIN. Sometimes you see that, and not the partial VIN.
    The date code might have 9's look like 6's. 0's look like 6's and 9's. If you can't find the first letter, or you can't find the first number, you might have a shallow indentation block.
    I'm an ex Lab Technician. Any ASME approved Non Detructive Test Technician can find your actual VIN code even if its been ground off. The science of checking removed or defaced engine numbers been done for a long time...
    Now, an important question. Since Canadian blocks would be more likely to be damaged by freeze thaw
    or replaced with a Mexican Ford Remanufactored HO block, what color would the replacement be?
    Were Canadian service replacement blocks and heads painted early Ford blue?
    The spot in my picture should be generally where it is though right? I will try and clean it like you said, right now it is pretty dirty but I assumed the numbers would be fairly prominent.
    The original car was supposedly white but it has been painted blue. Not sure how common it would be to paint the engine as well though.
    I had pain and anguish everywhere. You don't want to screw up yor Pony, but dang, its hard to get the numbers exposed at times.
    Non Stock Repainting? Its V-E-R-Y common and creates a lot of issues trying to establish its history. When I studied in line sixes, in 9 years, every low mount big bellhousing block I saw had been painted; They were never painted from factory except the rocker and oil pan. I've only seen two standard 1982 blocks on the net, and the other six were painted black, red or a non standard shade of Ford blue. FTSU = **** The Sys' UP
    Seams like every one hates the stock un-painted, rusted post 1981 Ford block
    Oh and "I assumed the numbers would be fairly prominent"
    Yeah me too. But I had to really work it to find mine.
    my partial VIN was BR101037
    Detail is Stamp2, DateO116Y, Small Code 2J213, Engine No BR101037.
    All over the show, like a bunch of engravers having an argument...
    Once I had that, I checked the catwalk frame horn under the gaurd/hood shut line by pulling a passenger side front wheel, the plastic liner, and then went about photoing it with a mirror, and then flipping it in Paint
    No B this time, but R101037 again, but it takes effort to see it...
    Hard work finding just those two matches, and then there was the buck code which I couldn't find at all....
