Page 6 of 6 FirstFirst ... 456
Results 126 to 135 of 135
  1. #126
    Hoping to get a good jump on the interior this upcoming weekend.
    Has anyone installed a manual choke cable in their Fox? If so, where did you route the cable through the firewall?
  2. #127
    Manual choke installed, moved oil pressure gauge to radio panel.
    Fixed some wiring issues and installed an AC idler pulley and removed the pump, lines & condenser.
    Started to clean up the floor in preparation for laying the carpet... guess what, more cracks.
    I tried to weld them up, but the welder just blows straight through the rusty metal. Might have to cut it out and use some steel as a replacement... but I am not a welder or a fabricator at all.
    Any tips for welding rusty Fox floor pans?
  3. #128
    Sep 2010
    Lexington, MA
    Still have these wheels?? Springfield's not that far
    Quote Originally Posted by 99GTMichael View Post
    Long overdue pictures of a not very photogenic car. The 14" wagon wheels are killing me. Dad has sanctioned using a set of silver Pony wheels... but I might have to put tires on the Enkei mesh wheels instead.
    Ford Motorsport ignition and rev limiter works great. I bought the 5100-5900 RPM chip set, figuring a stock head '83 flat tappet will be out of steam by 5900. I noticed in a set of instructions that another user on here posted that the red wire on the FMS harness required 12v keyed. This was for the C301 box and I have the A301 box. On my harness, I already have 12v on the white wire from the vehicle harness side that turns into the red wire on the FMS harness so I guess I don't need to do anything about that?
    Also, if anyone is familiar with the fuel line/parking brake line fasteners... what would you call it? It is the coarse pointed threaded fastener with flanged hex head. Is this considered a bolt or a screw? I need to secure the fuel lines back up to the body.
  4. #129
    Apr 2012
    Springfield MO
    Yes, have a couple of sets actually but I think Springfield MISSOURI is kind of far....PM me though!
    MCA #110307
    83 GT T Top
    83 GT Convt
    84 GT Convt SOLD 08/18
  5. #130
    Sep 2010
    Lexington, MA
    Quote Originally Posted by 83GTJIM View Post
    PM sent.
  6. #131
    I've been busy doing a lot of carburetor tuning and fixing wiring harnesses.
    I prefer the Pony wheels. Probably could stand to have some lowering springs in the rear. That's pretty low on the list, however...
  7. #132
    Working on interior, carpet is installed. Needs to be cut for all console holes & whatnot. Don't remember how the headliner goes in at all... that'll be fun.
  8. #133
    Sep 2010
    Lexington, MA
    Keep at it! Truck looks good too
  9. #134
    This car? Again? Will it ever be finished? Probably not.
    Still in basically the same shape, but I've made it more angry with a 4778 double pumper carburetor and a bunch of distributor curving.
    Re-done headliner is sitting in the garage ready to go back in.
  10. #135
    Apr 2012
    Springfield MO
    Get after it boy.
    MCA #110307
    83 GT T Top
    83 GT Convt
