Originally Posted by
xctasy
There is a missfire DTC code. Pull the codes and check for it. A coil fault should be seen by diagnoisis, not via swap out. If you want to swap it out, do so, but please be aware the SPOUT control deals with idel matters...if the exhaust is creating an ignition problem, I would not be at all supprised.
Hey, I knew your car's fuel system would respond to the changes.
Well done on all the hard work! Your car is what I like about the smartness off the CFI system, despite the very poor 1965 era manifolding. Basically, except for the cross over passage and the EGR changes, the E4 intake is 289 C code. CFI likes single plane open runner, but Ford decided to use a reheated E0 manifold, and nothing has changed. Despite the hell for stout cam the 1984 CFI M code ran.
Please note that any wiriing specfication change is a bad idea...Ford designed the TFI for certain plug wires, plugs and a specific coil specfication. Bearing in mind the costs invloved, you might be better off sticking with the stock TFI spec wires.
