Hi guys. Im in the process of swapping a efi tank into my 79 coupe. Ive ordered the tank, grommet for the filler neck, pump hanger, grommet for vent valve, 86 sender, efi tank mounting straps, and a hfp pump. Couple questions i havent found answers to, and yes i have searched. Lol. Ive read the filler neck itself is bigger on the 79-81 tanks and wont fit into the tank. Another thread i read said theyre the same. Which is it? Do i need to change the plastic housing the neck bolts onto if i do need a efi neck, and what about the rubber gasket that goes around the neck to seal out stuff from getting into your trunk. Is the rubber gasket different? Can i use the vent valve out of my old 79 tank in the new efi tank? Thanks for any help.
