    Default My 1985 GT to add to the database
    Here are the photos of my door tag and buck plate.
    Sent from my LG-AS991 using Tapatalk
    How many miles on the odometer? Does this 1985 GT have any of the following options?
    • light group (light under hood and in glove box, buzzer when headlights on/driver door open/key NOT in ignition)
    • tinted glass (tinted windshield, slight tint to side and rear glass)
    • premium sound system ("Premium Sound" on factory radio face plate, amplifier beneath center of dash pad)
    • speed control (cruise control)
    What is the last digit near the screw on the buck tag (075_)? Is there is number on the bottom right corner of the buck tag?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    The odometer is 163,373 miles
    Does have the light group
    The windshield has the top tint side and rear don't appear to be tinted.
    Does not have premium sound or cruise control
    The screw is cut through the last no. at 075 can't make out what is there.
    The last numbers on the buck tag, bottom rt. corner are 1NLR.
    VIN
    1FA = Ford vehicle manufactured in USA by Ford Motor Company
    B = active belts, no airbags
    P = passenger car
    28 = Mustang 3-dr hatchback
    M = H.O. 5.0L V8 engine
    6 = VIN check digit
    F = 1985 model year
    F = Dearborn Assembly
    144929 = 44,929th 1985 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 01/85 = January 1985 scheduled build
    GVWR - 4051 lb/1837 kg = gross vehicle weight rating
    Fr GAWR - 2137 lb/969 kg = front gross axle weight rating
    Re GAWR - 1934 lb/877 kg = rear gross axle weight rating
    F0034 = 34 lbs front accessory reserve load
    R0071 = 71 lbs rear accessory reserve load
    Exterior Paint Colors - 1C = Black
    DSO - 22 = Charlotte district sales office
    Body - 61B = Mustang 3-dr hatchback
    Int Trim - PA = cloth Articulated Sport seats (P), Charcoal/Grey interior color (A)
    A/C - 1 = Dark Charcoal hood stripe, Medium Charcoal "Mustang GT" decal on hatchback
    R - 7 = non-electronic AM/FM stereo radio with cassette tape player
    S - C = sunroof
    Ax - M = 2.73:1 axle ratio, Traction-Lok differential
    Tr - 2 = manual Borg Warner transmission (5-speed T-5)
    BB = front springs
    SS = rear springs
    Buck Tag
    MUSTANG = Mustang model line
    MO = moonroof (sunroof)
    075_ = body & paint rotations #075_
    1CC = Black exterior paint color
    DF
    ST
    AC = manual air conditioner
    03 = YES rear wing, NO rear defrost
    GT = GT model/trim level
    MBW = manual Borg Warner transmission (5-speed T-5)
    01 = no hood scoop
    EL
    -A = Charcoal/Grey interior trim color
    03
    1
    X
    1
    NLR
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Thank you.
