Results 1 to 2 of 2
    Default Battery/Starter/Grounding Cables
    Hey guys, I'm not amazing at looking at wiring diagrams and I want to make sure I get all the cables to fully update mu 82 Capri RS 5.0. Swapped the solenoid and I want to make sure all the other cables are up to date.
    Does anyone have a legit list of all the cables I need?
    1. Positive Battery Cable
    2. Negative Cable to engine block?
    3. Negative Cable from block to Frame? (I think I've seen this online?)
    4. Solenoid to Starter Cable
    I just want to get a full refresh of these wires while I'm at it if possible. Sucks there isn't just a "battery cable kit" to update all this stuff.
    Any help would be awesome, thanks as always guys.
    Everything's different. You measure the lengths you need and get those. The fatter (lower gauge #) all the cables are, the better.
