Ok I have a 1985 gt with a 1990 mustang 5.0 motor in it it has an edelbrock 600 carb and I thinck it has a mild cam from wat I was told first question is what would be the ideal timing I have it set at 12 degrees advance that's stock Right and also when checking vacume with a vacume gauge where do I hook the gauge to the carb or the manifold and what should it be reading thanks for any info and if their is anything els I should be checking out let me know I'm also new at carbs I've always had fuel injection thanks in advance
