Results 1 to 18 of 18
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Default No crank 1990 3.8 Thunderbird
    Son number one bought a T-bird to get himself to work a few weeks ago.
    Ran great so far but now won't start. No crank.
    Everything seems to have power. Turn the key, dash, fuel pump all seem to power up.
    Turn key to start, solenoid clicks, positive wire torques from current, no crank. Son said last week once the starter kept spinning after start; shut off restarted and okay.
    This time he said it "started, ran, then died, then restarted "itself" (?). He shut it off and then nothing.
    I think starter. We tried yesterday to get it off to take it and test and replace but wouldn't you know one of the two bolts wouldn't come out. Mangled the head. Car is getting towed home so we can get it out rather than on the side of the street where he works.
    Am I right thinking seized or shorting starter? I'll double check the solenoid with the meter once I get it in the garage. Not like I don't have other things to work on right now...
    Thanks for any leads.
    Pic of said car:
    Darran
    Mar 2015
    Rose Hill,Kansas
    Looks pretty nice, my son has 95 t bird
    Jan 2003
    lansing, mi
    Check the starter solenoid out and see if it is sending power to the starter cable with a multimeter on DC volts setting when he tries to crank it. Also check the signal wire. It sounds like the solenoid or ignition switch may have some issues going on if the starter was sticking on. The solenoid should look like this:
    It should have a one wire movable pole starter on it like the four eyed cars do. These starters need a very good connection to power and ground, they pull a lot of current compared to the later mini starters. I would inspect and clean the battery terminals, the starter cable connections, the battery cable to solenoid connections, the screws that hold the solenoid to the car since the solenoid grounds through them, the engine grounds, and coat them with dielectric grease. Inspect al the cables. Take the battery to Crappy Tire or the like and have them load test it as well if the rest checks out.
    Cale
    Put the other bolt back in, safely raise the car, turn the key while the kid beats on it with a hammer. That will usually get you home without a tow truck.
    Go to harbor freight and get a wobbly extension set and then walmart for a bostich ratcheting handle 3/8" drive socket wrench.
    It will cost you about $40, but you wont get stuck on a starter again.
    Grand Rapids, MI
    Check the wires going right to the starter. I had a frequent no start issue on my old '93 SC quite a few years ago. I would put in a starter from my used starter pile. It would start for a week or so and then no luck. They all tested fine at the store. I finally went out and bought a new starter at the store. The new starter came with new leads going to the starter. Apparently they had issues with the wires corroding. After installing the new starter with the replacement wire leads I never had any more problems.
    Jan 2003
    lansing, mi
    ^^^Your 93 super coupe would have had the better pmgr starter on it. The o.p. should have only one cable going to his starter if Rock Auto's catalog isn't lying to me.
    Cale
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Thanks for all of the tips so far. Unfortunately, I never got to do anything today. The car is jacked up and ready to go in the garage. I was at a coworkers stag party last night so it was a couch day. Hopefully I can get at it one day after work this coming week.
    Darran
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    What voltage should the signal wire be giving the solenoid? I only measured 3.6-3.7vdc
    Now that I cleaned everything up and I am checking the voltages the solenoid isn't clicking anymore.
    Darran
    Unless there's something different in the system for that car, the signal wire (key, trigger) to the solenoid should have key-on battery level voltage... Is the battery okay, and the cables and such? Ignition switch in the column?...
    I concur with the fellas above. Any quirky stuck continual rotating of the starter and such will be the solenoid sticking in the triggered position.
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Thanks. This is the solenoid they gave me from auto value.
    Turning the key to run now still seems to prime the pump and power up the dash etc.
    Weird I'm getting the low voltage measure at the signal. All of the cables are good and just cleaned up.
    Darran
    Are you able to put the key in the Run position and jump the two large lugs on the solenoid and get it running? If it'll do that, that should rule out the battery (if it's at 12V or less stationary, it should be suspected as a dud or no longer taking a charge) and the starter (and all the cables) as the culprits. I'd try that and see how much (or if) it's charging (hopefully 14V+) while running. Otherwise, I'd follow that trigger wire where it goes and to where it should be somewhere in the ignition switch in the column, and see if things are loose or there's a sign things have gotten hot or something... lots of resistance can use up lots of voltage...
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Okay, so forgetful son forgot foot needs to be on brake to start. Almost full voltage. New solenoid probably wasn't needed.
    Power going to starter, cable from solenoid to starter torques with the current...no crank.
    Cut bolt head off, removed starter. Bolt is in tough still.
    Spayed some deep creep and sitting. Heat and/or pipe wrench will be next on the bolt. Wished I had a welder to weld a nut on.
    Darran
    News to me. I had a freind with a 94, never had to press on the brake to start it.
    It sounds like there are a few different wiring things that need to be sorted out.
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    I thought it weird also. After your reply I did a little look around and sure enough it seems like it was what you really needed to do: http://forums.tccoa.com/6-general-te...start-car.html
    One reply in the thread (I'm going to have to check our manual if it even has one):
    When in doubt, check the Owners Manual. My 90 manual says that on Automatic Trans cars, "make sure that the gearshift is in park, set the parking brake and depress the brake pedal before you turn the key. The starter will operate only if the brake is pushed down."
    Bolt is out I tried heat and vice grips with no success. The bolt is too hard to get a good grip. A 14" good quality pipe wrench did the trick! I chased the holes last night before I shut 'er down for the night. Today, starter in and hopefully start up.
    The new starter gear will turn both ways while I cannot turn the one that came out in one direction. It looks like a valve cover is leaking a little and may have been leaking down onto the starter over the years. Not sure if related but may be part of it.
    Jan 2003
    lansing, mi
    That's weird about having to have your foot on the brake to crank it. We had a 94 3.8 t-bird and it wasn't that way. The starter drive should only turn in one direction, it has an over running clutch so that it can drive the flywheel, but freewheel if the engine speed is higher than the starter's. If it turns in both directions, the drive is no good. Pretty well all the starters in the parts stores have low quality Chinese starter drives in them. I had to pull the Carquest starter off of my Capri to replace a failed Chinese starter drive.
    Were you using Vice Grip brand locking pliers, or the store branded ones? I have a set of them from Crappy Tire and they are pretty useless with stuff like this. The Vice Grip brand ones with the lever release are the only ones that are any good. There are new Vice Grips out that don't have the lever release. I have found those are as worthless as the store brand knockoffs. I'm glad you were able to get the bolt out.
    Cale
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Quote Originally Posted by cb84capri View Post
    Cale
    Thanks for the help Cale. For the starter drive differences I was commenting to I meant the new one would turn easily one way and with effort the other. The one that I pulled out turned in one direction easily and would not turn the other way.
    For the vice grips, I was using ViceGrip brand but they are older and may have seen better days but the bolt material seemed hard. Just glad it came out! I would have had a heck of a time trying to drill or anything!
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Thanks for the help everyone. I put the starter in in 10 minutes this morning. Hooked the battery back up, PRESSED THE BRAKE PEDAL, and the car fired right up!
    Amazing the pain one sticky, fricken bolt caused. We would have had it changed on the side of the street that first day if it wasn't for that bolt!
    Oh, and I checked the owners manual just to be sure:
    Grand Rapids, MI
    The early MN12's required the brake pedal to be depressed when starting. I think they did away with it after '91 maybe? My '92 did not need the brake pedal to be depressed. On the valve covers, check the valve cover bolts to make sure they are tight first. I've had several leaking valve covers on 3.8's through the years because the bolts loosened up on them.
