Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
  1. #26
    What area of town are you in? I should have some free time this weekend , 9 1 3 - six six 9 - for to ate nine, shoot me a call or text.
    83 Mustang GT , A5 5 speed, 31 spline Cobra rear, LMR TRX, 302 11r 190 heads, Buddy Rawls custom cam
    86 Capri , 342 stroker , AFR 185 heads, Track Heat intake, 3.73 gears
  2. #27
    Default Wheels
    Quote Originally Posted by 4eyedfoxdriver View Post
    I'm in Pleasant Hill, and I'll be around anytime Sunday, you can call me also 8167396606
  3. #28
    Which tires do you have on the LMR wheels?
  4. #29
    Question:-
    Quote Originally Posted by chazman View Post
    Answer:
    Thanks.
    I went 225 55 16 . I like running the same size all around, and I know 245's will rub up front.
    I have B springs in the rear, I'll install the front as soon as I have any reason to get into the front end. But if you look in the early pics you can see it always seemed to sit a little high in the rear. I should be happy if they drop the front a 1/2in.
  5. #30
    The TRX look right at home on the 83. I also really like the 10 holes on the aero.
    If nobody releases a 10 hole 5 lug I may get ticked and put my 86 back to 4 lug when it’s done. Haven’t decided, don’t need to right now.....
    If I would have found 5 lug mesh wheels initially for the Saleen build that might have sealed the deal on what gets what....
  6. #31
    Banned
    Feb 2017
    Birmingham AL
    I remember buying a sand beige coupe back in 1993 with the original TRX wheels on it. I was so sad when I had to get new tires and the guy behind the counter said $400.00, each.
    I told the guy the whole damn car didn't cost that much.... in the end I ended up getting a set of stock wheels that had the whole center/hubcap molded and fused onto the rim. They were so hideous. and it was a very sad day.
    I tried finding a picture on Gooogle but it seems that the internet has removed this horrid wheel from existence...
  7. #32
    Banned
    Feb 2017
    Birmingham AL
    Oh, I forgot. I think the TRX wheels look awesome on your ride.
  8. #33
    So I decided the TRX's would be better suited on the 83 and Boy was I right....
    Is the front suspension on that car bone stock? Still has the early k-member and arms?
    Wanted to gauge the fit of that wheel versus suspension width.
  9. #34
    Yep it's stock. Get some rubbing at full turn, but otherwise all good.
