Alright, so today i did a fuel pressure drainback test on my car. It loses pressure very quickly after i turn the engine off. Since i have braided stainless fuel lines, i don't feel comfortable squeezing them with a clamp to determine which side is causing the drainback problem i have. Therefore, i got an AN -6 female plug to put on the springlock connector adapter I have on my fuel rail. I plugged the return side and pressurized the system. It held about 19 lb for quite a while. Longer than i cared to wait. Honestly I thought the problem was the pump, but apparently not so. I reinstalled the return line and tried again. It lost pressure like usual. So, what that means is, i have a bad regulator, correct? It's an Aeromotive adjustable one. I have it adjusted to 40 lb. Where it's adjusted shouldn't affect whether it lets the pressure drain back though, right? I don't know much about aftermarket ones and why people like them. I liked it because it has a gauge port and i got a good deal on it. I've got nowhere else to put a gauge because since i went to the different fuel lines, there's no shroeder valve.
So, anyway, i was looking on Summit to see what a new one costs. I noticed there's a BBK adjustable regulator with the vacuum port on top, instead of on the side where it interferes with the EGR valve like the Aeromotive one has. But then I read the reviews, and they were pretty much ALL bad on the BBK! I guess that answers that!
So, i have this 155 lph BBK fuel pump i was going to swap to (I have a parts store stock replacement now) when i thought the pump was the problem. It's new in box, but I think it's really old. I got a good deal on it too, because of that. But now having seen the reviews on the BBK fpr, I'm worried I'll be yanking my damn tank out to replace it right away if i install it. What are your thoughts? I HATE pulling the gas tank.
If I were to go to a different pump, which one do you like? My combo is pretty much '93 Cobra (Explorer intake, 65mm throttle body, 24lb injectors GT40P heads), and i plan to do a cam in the future (TFS1 or something similar), as well as a custom tune. What LPH do I need that will allow for those upgrades? What brand do you like? Walboro seems reasonably priced...
Thanks in advance for your input!
