Results 1 to 4 of 4
    Default Can't Space in PM Replies
    I've never experienced this issue on other forums - I can not add a space between characters in the quick reply of a PM. If I go into advanced mode I can. Also, quick reply works within threads, but not in the PM system.
    Not a major issue, but just thought I'd point it out, as it is for sure an oddity.
    1985 1/2 SVO 2A - 260rwhp/295tq - Huber tuned engine, big valve head, roller cam, ported exhaust, upgraded turbo, new vane meter, air intake system, LA3, 35lb injectors.
    Quote Originally Posted by Jacob85.5 View Post
    I occasionally have the same issue not only when sending PMs, but even with replies to posts.
    I have found that if you hit the return key to start a new line, you can then add spaces. Not sure why that works, but I found that out by accident. Now when it happens, I just type the first word, hit the return/enter key and then use the arrow keys to move back up to the end of the word and type out what I need to.
    Hope that helps and works for you too!
    Glad to know the little trick! I'll utilize that.
    Oct 2004
    Ann Arbor MI
    thanks Im also having the problem. Of course not as I type this. But when replying to PM Messages
