sve 130 amp alternator upgrade (86 mustang GT), overall easy install done with hand tools. Exception: used dremel and cut off wheels to modify bracket.
notes: -bottom bolt on alternator must be tightened to threads at back of bracket before top bolt or will not line up.
- make sure 4g power cable is on correct post of starter solenoid - I simply did this by watching video which was different set up than my own.
(everything should be on post with postive battery cable except power cable going to starter!
